[Qgis-user] Merging 3 different Shapefiles
Duarte Carreira DCarreira at edia.pt
Mon Jun 7 01:24:37 PDT 2010
Ok, thanks. I've installed 1.5 now and will test shortly.
Regards,
Duarte
-----Mensagem original-----
De: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
Enviada: quarta-feira, 2 de Junho de 2010 19:31
Para: Duarte Carreira
Cc: qgis-user at lists.osgeo.org
Assunto: RE: [Qgis-user] Merging 3 different Shapefiles
In the "vector" menu you can now find a "merge vectors" tool. You'll
need to use qgis-dev you can install under windows with the osgeo4w
installer.
cheers
-- Giovanni --
On Wed, 2010-06-02 at 17:43 +0100, Duarte Carreira wrote:
> Pedro,
> If you have GRASS you can use v.patch to append data to an existing layer.
> The drawback is that you have to convert everything to Grass first, append 1 by 1, and then export it back out of grass.
> If you are on linux there are commands you can use to batch append shapefiles...
> I wish I knew a way to automate this kind of thing, without being a bash shell guru...
> Duarte
> Pedro Roma pedroroma1982 at gmail.com
> Thu May 6 08:05:08 EDT 2010
> Subject: [Qgis-user] Merging 3 different Shapefiles
> Greetings
> I need to merge 3 shapefiles, from different training areas, into only one.
> How can I do this in QGIS?
> Thanks
> Pedro
> Qgis-user mailing list
