[Qgis-user] TIFF style problem
Borys Jurgiel
borysiasty at aster.pl
Fri Jun 11 02:30:12 PDT 2010
Dnia piątek, 11 czerwca 2010 o 11:07:04 Milena Nowotarska napisał(a):
> Hi Błażej,
> W dniu 11 czerwca 2010 11:00 użytkownik Błażej Zamojski
> <bza at green-power.com.pl> napisał:
> > Hi!
> > I have problem with TIFFs style in QGIS 1.4 (Vista). They have
> > different shapes and around them there is no data (visible as black).
> > When I'm puting 0 in properties in field where should be a value of no
> > data I am loosing not only black frame but some pixels in the raster.
> > It doesnt happend with all rasters. Anyone had the same problem? I
> > tried to import styles from rasters without the problem, but it didn't
> > work.
> Have you tried MultiQml plugin for changing styles? For me it works fine.
I think it's not the point. The problem is probably in this bug:
https://trac.osgeo.org/qgis/ticket/2491
Note that if you set nodata to 0, all cells with 0 value get transludent, no
matter where they are.
B.
