[Qgis-user] bug? Save As of a DGN layer with only polygons saves as lines
Duarte Carreira
DCarreira at edia.pt
Tue Jun 15 11:50:30 PDT 2010
Hello, all.
I'm facing this unexpected behavior from QGIS.
I load a DGN file. I query the file to get only element type 6 (TYPE='6'), which is polygon.
I can symbolize the layer as polygons.
When I do "Save as", choose shapefile as output format, everything goes ok.
I then load the shapefile, and to my surprise it composed of lines.
Can anyone confirm this?
To workaround I created a new shapefile, edited, and did copy/paste from the dgn to the new shapefile. Everything went smoothly and saved as polygons.
Thanks,
Duarte
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100615/c58e2e83/attachment.html>
