[Qgis-user] get a world file with georeferencing
Richard Duivenvoorde richard at duif.net
Thu Jun 17 01:50:27 PDT 2010
On 06/17/2010 08:59 AM, Marco Hugentobler wrote:
> Hi Richard
> If you go to the transformation settings and select linear transformation, you
> have the options to give an output filename ( in this case, the raster is
> resampled according to the options) or to leave the output filename blank (in
> this case, a worldfile is created).
Hi Marco,
thanks, got it now...
Some observations:
- if you leave the outputfilename empty, the worldfile will be created
next to the image you loaded (great)
- if you give only a filename (without path) the raster file is saved in
your homedir.
Wouldn't it easier to also save it next to your original image?
- it's a little hidden feature, don't you find?
Is there a way to make it easier to know for a user? Or just add an
extra input box for it?
Richard
