[Qgis-user] where is the correct answer ...
    Micha Silver
    micha at arava.co.il
    Sat Jun 26 05:55:40 PDT 2010
On 06/26/2010 03:40 PM, herman palaquium wrote:
> AREA: 2.7e-05
> KebunPoly: KebunAmran1
> Luas: 0
> PERIMETER: 0.024863
> Panjang: 0
> please help the area and perimeter unit
The numbers above indicate area: 0.000027 square units.
If, by mistake, you projection units is degrees, instead of meters, then
this would be 0.000027 square degrees. One sq deg ~= 110 km X 110 km, or
about 12,000 sq km. So the above would translate to approximately
327,000 sq meters. Does that make more sense?
Again, if your units are degrees, not meters, then the perimeter would
be around 2,730,000 meters. (110 km/deg X 0.2483 )
> my projection is meter
> where is the correct 2,4863 meter
> or 24,863 meter
> or 248,63 meter
> or 2486,3 meter
> or 24863 meter
> or any answer the correct
> and than
> where is the correct area answer ?
> 0,27 ha
> 2,7 ha
> 27 ha
> 270 ha
> herman
> indonesia
> Qgis-user mailing list
> This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
