[Qgis-user] where is the correct answer ...
Micha Silver micha at arava.co.il
Sat Jun 26 13:13:58 PDT 2010
On 06/26/2010 08:47 PM, Nicklas Avén wrote:
> Hallo
> hmm, is this right Micha. Isn't the size of a sqare degree depending
> on how far from equator it is. Since the vertical longitudes are
> convergating to the poles 1 west-east degree is 0 at the pole and
> about 40000/360 km at the equator which makes the conversion difficult.
Yes, of course. The numbers below are only rough estimates. I think
Herman was trying to understand in general what his results meant.
> /Nicklas
> ----- Ursprungsmeddelande -----
> > On 06/26/2010 03:40 PM, herman palaquium wrote:
> > > AREA: 2.7e-05
> > > KebunPoly: KebunAmran1
> > > Luas: 0
> > > PERIMETER: 0.024863
> > > Panjang: 0
> > > please help the area and perimeter unit
> > The numbers above indicate area: 0.000027 square units.
> > If, by mistake, you projection units is degrees, instead of meters,
> then
> > this would be 0.000027 square degrees. One sq deg ~= 110 km X 110
> km, or
> > about 12,000 sq km. So the above would translate to approximately
> > 327,000 sq meters. Does that make more sense?
> > Again, if your units are degrees, not meters, then the perimeter would
> > be around 2,730,000 meters. (110 km/deg X 0.2483 )
> > > my projection is meter
> > > where is the correct 2,4863 meter
> > > or 24,863 meter
> > > or 248,63 meter
> > > or 2486,3 meter
> > > or 24863 meter
> > > or any answer the correct
> > > and than
> > > where is the correct area answer ?
> > > 0,27 ha
> > > 2,7 ha
> > > 27 ha
> > > 270 ha
> > > herman
> > > indonesia
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > This mail was received via Mail-SeCure System.
> > Micha Silver
> > Arava Development Co. +972-52-3665918
> > http://www.surfaces.co.il
Micha Silver
http://surfaces.co.il
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100626/9b506689/attachment.html>
