[Qgis-user] multiple lines label not working
Jürgen E. Fischer jef at norbit.de
Mon Jun 28 04:19:31 PDT 2010
Hi Maning,
On Mon, 28. Jun 2010 at 18:27:11 +0800, maning sambale wrote:
> In the layer properties labels tab, there is an option for
> multiplelines labels.  I added "/n" into the label name attribute then
> activated the multiplelines option.
You have to enter a "real" newline.  If you want to enter multiline labels in
QGIS you need to assign a TextEdit instead of LineEdit as edit widget in the
vector layer properties' attributes tab.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
