[Qgis-user] obsolete plugin message
Vincent Schut schut at sarvision.nl
Tue Jun 29 03:20:58 PDT 2010
  On 06/29/2010 12:12 PM, Borys Jurgiel wrote:
> Dnia wtorek, 29 czerwca 2010 o 12:04:22 Vincent Schut napisaƂ(a):
>>    Hi,
>> when starting a fresh svn build of qgis, I get a message about a plugin
>> being obsolete:
>> "The Plugin Installer has detected an obsolete plugin which masks a
>> newer version shipped with this QGIS version. This is likely due to
>> files associated with a previous installation of QGIS. Please use the
>> Plugin Installer to remove that older plugin in order to unmask the
>> newer version shipped with this copy of QGIS."
>> I have many plugins installed... How would I know which one to remove?
> Sorry, the plugin name isn't well exposed - it's in the title of the message
> box.
> I'm sure this time it's Plugin Installer itself. Note that removing the
> installer with itself raises an error - it's ok, I've fixed this error in the
> new version, but the previous one is affected.
Ah, and because it's the plugin installer plugin, I was thinking that
was just the plugin issuing the message... Tricky :-)
Removed the plugin installer, getting all kinds of errors, just closing
qgis and restarting, and then all seems fine again.
Thanks!
VS.
