[Qgis-user] Re: Using -> OGR Layer Converter <- For GML to PostGIS
Mars Sjoden
aurorageomatics at gmail.com
Tue Jun 29 21:54:48 PDT 2010
Sorry, the parameters did not get pasted
SOURCE
> *FORMAT: * GML
*DATASET:* /GISWorkspace/GML/2010-JUNE/RESULTS_OPENINGS_FCRESERVES.GML
TARGET
> *FORMAT: *PostgreSQL
*DATASET:* PG:dbname='MyDatabase' user='MyUserName' password='MyPassword'
*LAYER:* RESULTS_FORESTCOVER_RESERVES
thank you.
mars
On Tue, Jun 29, 2010 at 9:47 PM, Mars Sjoden <aurorageomatics at gmail.com>wrote:
> Hello,
> I have been receiving public .gml files from the BC Ministry of Forests and
> I quickly review them in QGIS.
> I also wish to quickly add these .gml files to our PostGIS databases, and
> noticed there is a GUI front end plugin "OGR Layer Converter".
> I have tried the plugin a couple times using the following parameters:
> I am able to import the GML file into PostGIS however the Column Table are
> not exported over.
> The newly created PostGIS layer "RESULTS_FORESTCOVER_RESERVES" will load
> the spatial into QGIS correctly, lacking the Columns.
> Any pointers would be greatly appreciated.
> Also, here is an example excerpt of the GML that the BC MOF exports to me
> incase this is a syntax issue parsing the GML
> <?xml version="1.0" encoding="UTF-8"?>
>> <FeatureCollection xmlns:gml="http://www.opengis.net/gml">
>> <gml:featureMember>
>> <FOREST_COVER_RESERVE fid="5">
>> <OPENING_ID>1234567</OPENING_ID>
>> <FOREST_FILE_ID>A9595959</FOREST_FILE_ID>
>> <CUTTING_PERMIT_ID>886</CUTTING_PERMIT_ID>
>> <CUT_BLOCK_ID>003</CUT_BLOCK_ID>
>> <SILV_POLYGON_NO>A</SILV_POLYGON_NO>
>> <SILV_POLYGON_AREA>7.7</SILV_POLYGON_AREA>
>> <SILV_RESERVE_CODE>W</SILV_RESERVE_CODE>
>> <SILV_RESERVE_OBJECTIVE_CODE>WTR</SILV_RESERVE_OBJECTIVE_CODE>
>> <ENTRY_USERID>BCEID\USERID</ENTRY_USERID>
>> <GEOMETRY.AREA>0</GEOMETRY.AREA>
>> <GEOMETRY.LEN>0</GEOMETRY.LEN>
>> <GEOMETRY>
>> <gml:MultiPolygon>
>> <gml:polygonMember>
>> <gml:Polygon>
>> <gml:outerBoundaryIs>
>> <gml:LinearRing>
>> <gml:coordinates>941509.249,1060062.342 941510.887,1060056.694
>>> 941510.01</gml:coordinates>
>> </gml:LinearRing>
>> </gml:outerBoundaryIs>
>> </gml:Polygon>
>> </gml:polygonMember>
>> </gml:MultiPolygon>
>> </GEOMETRY>
>> </FOREST_COVER_RESERVE>
>> </gml:featureMember>
>> </FeatureCollection>
> Thank you!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100629/8de331c4/attachment.html>
