[Qgis-user] Segmentation fault...
Pedro Tarroso ptarroso at mail.icav.up.pt
Mon Mar 1 07:39:45 PST 2010
Hi
Thank you all for the answers (obrigado Giovanni!). I think what happened is the same thing that Micha describes. It was the last week (and I suppose after that upgrade) that the software begun to give the seg fault. I don't have the xfce installed but I will try to have a look to it.
Cheers,
Pedro
-----Original Message-----
Sent: Mon 3/1/2010 3:25 PM
To: Pedro Tarroso
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Segmentation fault...
On 03/01/2010 03:26 PM, Pedro Tarroso wrote:
> Hi
> I'm trying to use QGIS 1.0.2 on a Fedora 11 machine but I get all the
> time a Segmentation Fault error...  I have looked in some forums for
> similar problems and there was a common problem about Qt. However, I
> already tried the Qt config without success. The strange behaviour is
> that QGIS runs fine as a super user! Can it be some permissions? Any idea?
I found the same problem running QGIS 1.4 on Fedora 12 after a yum
update recently (Feb 24 I think) which upgraded some qt packages. I also
find that QGIS starts when run as super user, and in addition, if I
switch to xfce instead of Gnome, QGIS starts fine (as a regular user).
Can you verify that under xfce (if you have that window manager
installed) on your setup it works?
Thanks,
Micha
> Thanks!
> Pedro
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
Micha Silver
http://www.surfaces.co.il/
Arava Development Co.  +972-52-3665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100301/23d985b9/attachment.html>
