[Qgis-user] Working with ESRI mdb geodatabase file
Piotr Pachół piotr.pachol at wodgik.katowice.pl
Wed Mar 3 08:09:39 PST 2010
Thanks, it is working !
But one question: is it possible to display coded value domains which I
have defined in mdb file ?
Piotr
G. Allegri pisze:
> If you're working on Windows you should first create an ODBC
> connection through Administrative Tools.
> giovanni
> Hello,
>>> I have ESRI mdb geodatabase file.
>>> How can I create a database connection to this file ?
>>> When I try to use option: "Add vector layer/Create database
>>> connection/ESRI Personal Geodatabase"
>>> I have an error: "Unable to initialize ODBC connection to DSN"
>>> So what should  fill in connection information ? (host, database, port)
>>> Where I can fill in full path with name and extension of file ?
>>> Piotr
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
