[Qgis-user] Printing to letter size landscape results in 8.5x8.5 image
NoOp
glgxg at sbcglobal.net
Fri Mar 12 16:31:27 PST 2010
I am using the following (linux Ubuntu 9.10 Karmic):
$ apt-cache policy qgis
qgis:
Installed: 1.4.0-2~karmic2
Candidate: 1.4.0-2~karmic2
Version table:
*** 1.4.0-2~karmic2 0
500 http://ppa.launchpad.net karmic/main Packages
100 /var/lib/dpkg/status
1.3.0-1~karmic9 0
$ apt-cache policy cups-pdf
cups-pdf:
Installed: 2.5.0-8ubuntu1
Candidate: 2.5.0-8ubuntu1
Version table:
*** 2.5.0-8ubuntu1 0
500 http://archive.ubuntu.com karmic/universe Packages
and find that if I print to the cups-pdf printer from Print Composer
with the settng Ansi A (Letter; 8.5x11 inches) (Landscape) the result is
the image appears to be 8.5x8.5 inches.
However, if I use the 'export as PDF' function, the image properly
scales to the full 8.5x11 inches.
It doesn't appear to be a cups-pdf issue as printing directly to my
Canon MP750 results in the same 8.5x8.5 inches.
Note: printing to the cups-pdf printer and Canon from all other
applications works without issue.
Is this a known issue? Any workarounds?
