[Qgis-user] problems deleting column of shapefile attribute table
Giovanni Manghi giovanni.manghi at gmail.com
Wed Mar 17 05:31:08 PDT 2010
On Wed, 2010-03-17 at 08:27 -0400, Tara Athan wrote:
> When I open the attribute table of the loaded shapefile, the delete
> column is disabled (whether the edit mode is toggled or not). If I edit
> the dbf file as a spreadsheet (using OpenOffice) and try to load the
> layer, it doesn't recognize the dbf file.
deleting columns in. dbf is not (yet) supported by ogr.
http://trac.osgeo.org/gdal/ticket/2671
Nevertheless for shapefiles under qgis you can use the "table manager"
plugin to delete columns.
cheers
-- Giovanni --
