[Qgis-user] Creating polygon from points in csv file
nikos ves
vesnikos at gmail.com
Wed May 12 10:49:43 PDT 2010
On Wed, 2010-05-12 at 12:11 -0500, mir wrote:
> Hello all,
> I have a list of points in sequence that define a polygon. This is
> taken from a legal document defining a piece of land. So far I have
> been able to import this into Qgis as points. How do I import it as a
> polygon (or convert the points to a polygon? I have tried to use
> GRASS, importing it as an ASCII file, but I guess I never got the
> ASCII polygon format down.
> I'm sure there must be an asy way. Help!
> mir
You can use the "Points2One" plugin which makes the task you need.
As input takes a point layer and as output gives a polygon or a
polyline. In your case you can choose polygon.
Be careful with the order of the points, otherwise you might get funny
results.
eg |1 2| is fine , but
|4 3|
|1 2| will intersect with itself, making two triangles!
|3 4|
Ves Nikos
