[Qgis-user] QGIS1.5 on Win (standalone installation): Problem with VRT
Giuseppe Sucameli
sucameli at faunalia.it
Tue Nov 2 11:22:28 PDT 2010
Hi Agus,
the Raster/BuildVRT calls the gdalbuildvrt executable [1].
The default gdalbuildvrt behavior is to create a VRT which has as many bands
as one of the input files.
You should use "-separate" option to make sure that each files goes into a
separate **band.
The "-separate" option is available from gdal1.7, but in this moment you
cannot
tick the option from the Raster/BuildVRT tool.
Cheers.
[1] http://www.gdal.org/gdalbuildvrt.html
On Tue, Nov 2, 2010 at 1:45 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Just to report that this problem is still present when making a VRT file
> using "Raster/Build virtual raster (catalog)": I've made another vrt file
> and had to add the 2 lines:
> </VRTRasterBand>
> <VRTRasterBand dataType="UInt16" band="2">
> for each layer as suggested by Benoit in August.
> I've filled a ticket.
> Agus
> 2010/8/11 Benoit de Cabissole <benoit at exigesa.com>:
> > Agus,
> > Please try the following:
> > (note the comments in the xml to help you see the changes)
> > <VRTDataset rasterXSize="3001" rasterYSize="2554">
> > <SRS>PROJCS["WGS 84 / UTM zone 26N",GEOGCS["WGS
> > 84",DATUM["WGS_1984",SPHEROID["WGS
> 84",6378137,298.2572235630016,AUTHORITY["EPSG","7030&quo
> t;]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich&qu
> ot;,0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG"
> ;,"4326"]],PROJECTION["Transverse_Mercator"],PARAMETER[&
> quot;latitude_of_origin",0],PARAMETER["central_meridian",-27]
> ,PARAMETER["scale_factor",0.9996],PARAMETER["false_easting&qu
> ot;,500000],PARAMETER["false_northing",0],UNIT["metre",1
> ,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG",&q
> > uot;32626"]]</SRS>
> > <GeoTransform> 6.5222487132554676e+005, 4.0000000000000000e+000,
> > 0.0000000000000000e+000, 4.1899966827195832e+006,
> > 0.0000000000000000e+000,-4.0000000000000000e+000</GeoTransform>
> > <VRTRasterBand dataType="UInt16" band="1">
> > <ColorInterp>Gray</ColorInterp>
> > <SimpleSource>
> > <SourceFilename
> > relativeToVRT="1">po_172227_blu_0000000.tif</SourceFilename>
> > <SourceBand>1</SourceBand>
> > <SourceProperties RasterXSize="3001" RasterYSize="2554"
> > DataType="UInt16" BlockXSize="3001" BlockYSize="256"/>
> > <SrcRect xOff="0" yOff="0" xSize="3001" ySize="2554"/>
> > <DstRect xOff="0" yOff="0" xSize="3001" ySize="2554"/>
> > </SimpleSource>
> > <!-- added following two lines -->
> > </VRTRasterBand>
> > <SimpleSource>
> > <SourceFilename
> > relativeToVRT="1">po_172227_grn_0000000.tif</SourceFilename> <!--
> > changed relativeToVRT to 1 -->
> > </SimpleSource>
> > </VRTRasterBand>
> > <VRTRasterBand dataType="UInt16" band="3">
> > <SimpleSource>
> > <SourceFilename
> > relativeToVRT="1">po_172227_nir_0000000.tif</SourceFilename> <!--
> > </SimpleSource>
> > </VRTRasterBand>
> > <VRTRasterBand dataType="UInt16" band="4">
> > <SimpleSource>
> > <SourceFilename
> > relativeToVRT="1">po_172227_red_0000000.tif</SourceFilename> <!--
> > </SimpleSource>
> > </VRTRasterBand>
> > </VRTDataset>
> > This should hopefully do it.
> > Otherwise, is your data type really UInt16, can it be coerced to bytes?
> > Cheers,
> > Benoit
> >> -----Original Message-----
> >> From: Agustin Lobo [mailto:alobolistas at gmail.com]
> >> Sent: Tuesday, 10 August 2010 22:37
> >> To: Benoit EXIGE
> >> Cc: qgis-user; arturgil at gmail.com; cavallini at faunalia.it
> >> Subject: Re: [Qgis-user] QGIS1.5 on Win (standalone installation):
> >> Problem with VRT
> >> Thanks, I've done as below and the problem remains.
> >> Should I fill a ticket?
> >> 84",6378137,298.2572235630016,AUTHORITY["EPSG",&quo
> >> t;7030"]],AUTHORITY["EPSG","6326"]],PRIME
> >> M["Greenwich",0],UNIT["degree",0.0174532925199
> >> 433],AUTHORITY["EPSG","4326"]],PROJECTION[&quo
> > t;Transverse_Mercator"],PARAMETER>
> > ["latitude_of_origin",0],PARAMETER["central_meridia
> >> n",-27],PARAMETER["scale_factor",0.9996],PARAMETER[
> > "false_easting",500000],PARAMETER>
> > ["false_northing",0],UNIT["metre",1,AUTHORITY[
> > "EPSG","9001>
> > "]],AUTHORITY["EPSG","32626"]]</SRS>
> >> <SimpleSource>
> >> <SourceFilename
> >> </SimpleSource>
> >> <SimpleSource>
> >> <SourceFilename
> >> relativeToVRT="2">po_172227_grn_0000000.tif</SourceFilename>
> >> </SimpleSource>
> >> <SimpleSource>
> >> <SourceFilename
> >> relativeToVRT="3">po_172227_nir_0000000.tif</SourceFilename>
> >> </SimpleSource>
> >> <SimpleSource>
> >> <SourceFilename
> >> relativeToVRT="4">po_172227_red_0000000.tif</SourceFilename>
> >> </SimpleSource>
> >> </VRTRasterBand>
> >> </VRTDataset>
> >> 2010/8/10 Benoit EXIGE <benoit at exigesa.com>:
> >> > Hi Agus,
> >> > Looks to me that the <sourceband> should be incremented from 1
> >> to 4 for your
> >> > four rasters.
> >> > Hope this helps.
> >> > Benoit
> >> > Sent from my iPod
> >> > On 10 Aug 2010, at 21:01, Agustin Lobo <alobolistas at gmail.com> wrote:
> >> >> Hi!
> >> >> I use the gdal utilities (raster/Build Virtual Raster) with 4 files
> but
> >> >> then QGIS sees one band only (only one band listed in the Properties
> >> >> dialog).
> >> >> This is the VRT file, could anyone tell me if this is correct?
> > "EPSG","9001>
> >> >> <SimpleSource>
> >> >> <SourceFilename
> >> >> </SimpleSource>
> >> >> <SimpleSource>
> >> >> <SourceFilename
> >> >> </SimpleSource>
> >> >> <SimpleSource>
> >> >> <SourceFilename
> >> >> </SimpleSource>
> >> >> <SimpleSource>
> >> >> <SourceFilename
> >> >> </SimpleSource>
> >> >> </VRTRasterBand>
> >> >> </VRTDataset>
> >> >> Thanks
> >> >> Agus
> >> >> _______________________________________________
> >> >> Qgis-user mailing list
> >> >> Qgis-user at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101102/55001d5b/attachment.html>
