[Qgis-user] Re: QGIS 1.5 on Ubuntu 10.04 crashes
Alex Mandel
tech_dev at wildintellect.com
Tue Nov 2 23:34:23 PDT 2010
I've also been having issues on my 32 bit install (my 64 bit works fine)
from Ubuntugis repos, but a self compiled version works fine. I have not
been able to track down the issue but the last time I had something
similar it was a conflicting library somewhere in Qt. But that's really
just a guess to start.
Which binaries are you using?
Thanks,
Alex
On 11/02/2010 08:35 AM, Agustin Lobo wrote:
> Also, in case this provides any useful information,
> I've seen that my System Log has entries such as:
> Nov 2 16:07:11 delia kernel: [ 1011.502133] qgis.bin[2339]: segfault
> at 0 ip 00007f976722a2fd sp 00007fff3bc4b0d0 error 4 in
> libQtCore.so.4.6.2[7f976708d000+276000]
> Nov 2 16:10:09 delia kernel: [ 1188.912519] qgis.bin[3511] trap stack
> segment ip:7fd517ae02fd sp:7fff314d4230 error:0
> Nov 2 16:10:57 delia kernel: [ 1236.902324] qgis.bin[3567]: segfault
> at 0 ip 00007f3f8aa5c2fd sp 00007fffd885db00 error 4 in
> libQtCore.so.4.6.2[7f3f8a8bf000+276000]
> Nov 2 16:13:01 delia kernel: [ 1361.223289] qgis.bin[3591]: segfault
> at 0 ip 00007fa00adbc101 sp 00007fffe1ef3b00 error 4 in
> libQtCore.so.4.6.2[7fa00ac1f000+276000]
> Nov 2 16:14:12 delia kernel: [ 1431.700704] qgis.bin[3628]: segfault
> at 0 ip 00007f7b96395101 sp 00007fff7bd5ab00 error 4 in
> libQtCore.so.4.6.2[7f7b961f8000+276000]
> Nov 2 16:15:17 delia kernel: [ 1496.781699] qgis.bin[3649] trap stack
> segment ip:7fc37d98e2fd sp:7fff184bad90 error:0
> Nov 2 16:23:56 delia kernel: [ 2015.454881] qgis.bin[4979]: segfault
> at 0 ip 00007f2acc29b2fd sp 00007fff65323250 error 4 in
> libQtCore.so.4.6.2[7f2acc0fe000+276000]
> Agus
> 2010/11/2 Agustin Lobo <alobolistas at gmail.com>:
>> Hi,
>> After a crash while trying to load a vector layer, QGIS crashes all time:
>> the program starts, but as soon as I try to open any project or any layer or
>> to create a new layer, the program crashes with Segmentation Fault.
>> I've tried qgis --noplugins, same behavior.
>> I'm using ubuntu 10.04 and the binaries of 1.5 from ubuntugis/unstable
>> Any idea on what to do?
>> Thanks
>> Agus
