[Qgis-user] two little new plugins
Möri Cedric
Cedric.Moeri at bd.so.ch
Sun Nov 14 08:39:42 PST 2010
Hi list
I just released two little plugins: traceDigitize and numericalDigitize. Both work on vector layers which are in edit mode.
NumericalDigitize just opens a dialog with a table where you may enter x/y-values. After clicking ok, it will add a feature to your vectorlayer. The type of the feature is according to your layertype (point,line or polygon).
TraceDigitize works only for line and polygon layers. It allows to digitize new features by following existing lines or polygon boundaries. The tool will add all vertex points, that are in snapping distance of the cursor. Just press ctrl key while moving the mouse. If control isn't pressed, it is just like the normal digitize tool. Don't forget to set the (background) snapping options, as the tool needs them.
regards
Cédric
mit freundlichen Grüssen
Cédric Möri
GIS-Informatiker
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon: +41 (0)32 627 24 75
Telefax: +41 (0)32 627 22 14
mailto:cedric.moeri at bd.so.ch
http://www.agi.so.ch
