[Qgis-user] Download points from Garmin GPS 60
Albin Blaschka
albin.blaschka at standortsanalyse.net
Mon Nov 22 05:41:34 PST 2010
Hello!
Mhmm...tricky...
* First question: Is it a USB or serial device? (same question as Micha...)
* Did it work already? Has it stopped working after an upgrade for
example or something similar...?
* Sorry - as I dropped in a little later into the thread, maybe you have
already answered it...
I googled a bit and found messages reporting some problems with certain
kernel versions under ubuntu...
maybe this procedure described here helps...
http://www.absolutelytech.com/2010/04/18/solved-unable-to-enumerate-usb-device-disabling-ehci_hcd/
Kind regards,
Albin
Am 22.11.2010 14:09, schrieb Arthur Nanni:
> For a few seconds the gps was in the connected status. At this moment
> the dmesg returns:
> [ 0.291512] pci_bus 0000:1a: resource 0 io: [0x7000-0x7fff]
> [ 0.291515] pci_bus 0000:1a: resource 1 mem: [0xf2200000-0xf22fffff]
> [ 0.291517] pci_bus 0000:1a: resource 2 pref mem
> [0x80a00000-0x80bfffff]
> [ 0.291520] pci_bus 0000:26: resource 3 io: [0x00-0xffff]
> [ 0.291522] pci_bus 0000:26: resource 4 mem: [0x000000-0xffffffff]
> [ 0.291562] NET: Registered protocol family 2
> [ 0.291659] IP route cache hash table entries: 32768 (order: 5,
> 131072 bytes)
> [ 0.291969] TCP established hash table entries: 131072 (order: 8,
> 1048576 bytes)
> [ 0.292425] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
> [ 0.292677] TCP: Hash tables configured (established 131072 bind 65536)
> [ 0.292679] TCP reno registered
> [ 0.292764] NET: Registered protocol family 1
> [ 0.292963] pci 0000:01:00.0: Boot video device
> [ 0.292996] Simple Boot Flag at 0x36 set to 0x1
> [ 0.293149] cpufreq-nforce2: No nForce2 chipset.
> [ 0.293176] Scanning for low memory corruption every 60 seconds
> [ 0.293306] audit: initializing netlink socket (disabled)
> [ 0.293315] type=2000 audit(1290426910.291:1): initialized
> [ 0.302485] highmem bounce pool size: 64 pages
> [ 0.302490] HugeTLB registered 4 MB page size, pre-allocated 0 pages
> [ 0.303912] VFS: Disk quotas dquot_6.5.2
> [ 0.303965] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
> [ 0.304493] fuse init (API version 7.13)
> [ 0.304572] msgmni has been set to 1681
> [ 0.304769] alg: No test for stdrng (krng)
> [ 0.304816] Block layer SCSI generic (bsg) driver version 0.4
> loaded (major 253)
> [ 0.304819] io scheduler noop registered
> [ 0.304821] io scheduler anticipatory registered
> [ 0.304822] io scheduler deadline registered
> [ 0.304858] io scheduler cfq registered (default)
> [ 0.305009] alloc irq_desc for 24 on node -1
> [ 0.305011] alloc kstat_irqs on node -1
> [ 0.305019] pcieport 0000:00:01.0: irq 24 for MSI/MSI-X
> [ 0.305026] pcieport 0000:00:01.0: setting latency timer to 64
> [ 0.305155] alloc irq_desc for 25 on node -1
> [ 0.305156] alloc kstat_irqs on node -1
> [ 0.305165] pcieport 0000:00:1c.0: irq 25 for MSI/MSI-X
> [ 0.305176] pcieport 0000:00:1c.0: setting latency timer to 64
> [ 0.305327] alloc irq_desc for 26 on node -1
> [ 0.305329] alloc kstat_irqs on node -1
> [ 0.305338] pcieport 0000:00:1c.1: irq 26 for MSI/MSI-X
> [ 0.305349] pcieport 0000:00:1c.1: setting latency timer to 64
> [ 0.305501] alloc irq_desc for 27 on node -1
> [ 0.305502] alloc kstat_irqs on node -1
> [ 0.305511] pcieport 0000:00:1c.2: irq 27 for MSI/MSI-X
> [ 0.305522] pcieport 0000:00:1c.2: setting latency timer to 64
> [ 0.305675] alloc irq_desc for 28 on node -1
> [ 0.305676] alloc kstat_irqs on node -1
> [ 0.305685] pcieport 0000:00:1c.3: irq 28 for MSI/MSI-X
> [ 0.305696] pcieport 0000:00:1c.3: setting latency timer to 64
> [ 0.305850] alloc irq_desc for 29 on node -1
> [ 0.305852] alloc kstat_irqs on node -1
> [ 0.305860] pcieport 0000:00:1c.4: irq 29 for MSI/MSI-X
> [ 0.305871] pcieport 0000:00:1c.4: setting latency timer to 64
> [ 0.305972] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
> [ 0.306158] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
> [ 0.307319] ACPI: AC Adapter [ACAD] (on-line)
> [ 0.307390] input: Lid Switch as
> /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
> [ 0.307426] ACPI: Lid Switch [LID0]
> [ 0.307472] input: Power Button as
> /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
> [ 0.307474] ACPI: Power Button [PWRB]
> [ 0.307515] input: Power Button as
> /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
> [ 0.307517] ACPI: Power Button [PWRF]
> [ 0.308265] ACPI: SSDT 7fd1aca0 00223 (v01 PmRef Cpu0Ist 00003000
> INTL 20050624)
> [ 0.308726] ACPI: SSDT 7fd19620 00549 (v01 PmRef Cpu0Cst 00003001
> INTL 20050624)
> [ 0.310711] Monitor-Mwait will be used to enter C-1 state
> [ 0.310737] Monitor-Mwait will be used to enter C-2 state
> [ 0.310742] Marking TSC unstable due to TSC halts in idle
> [ 0.310792] processor LNXCPU:00: registered as cooling_device0
> [ 0.311198] ACPI: SSDT 7fd1aa20 001CF (v01 PmRef ApIst 00003000
> INTL 20050624)
> [ 0.311552] ACPI: SSDT 7fd1af20 0008D (v01 PmRef ApCst 00003000
> INTL 20050624)
> [ 0.312064] Switching to clocksource hpet
> [ 0.315762] processor LNXCPU:01: registered as cooling_device1
> [ 0.338249] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
> [ 0.339506] brd: module loaded
> [ 0.339932] loop: module loaded
> [ 0.340033] input: Macintosh mouse button emulation as
> /devices/virtual/input/input3
> [ 0.340419] Fixed MDIO Bus: probed
> [ 0.340452] PPP generic driver version 2.4.2
> [ 0.340482] tun: Universal TUN/TAP device driver, 1.6
> [ 0.340484] tun: (C) 1999-2004 Max Krasnyansky <maxk at qualcomm.com
> <mailto:maxk at qualcomm.com>>
> [ 0.340553] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
> [ 0.340578] ehci_hcd 0000:00:1a.7: PCI INT C -> GSI 19 (level, low)
> -> IRQ 19
> [ 0.340595] ehci_hcd 0000:00:1a.7: setting latency timer to 64
> [ 0.340599] ehci_hcd 0000:00:1a.7: EHCI Host Controller
> [ 0.340626] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned
> bus number 1
> [ 0.340655] ehci_hcd 0000:00:1a.7: debug port 1
> [ 0.344538] ehci_hcd 0000:00:1a.7: cache line size of 32 is not
> supported
> [ 0.344556] ehci_hcd 0000:00:1a.7: irq 19, io mem 0xf2504800
> [ 0.348490] isapnp: Scanning for PnP cards...
> [ 0.365602] ACPI: Battery Slot [BAT1] (battery present)
> [ 0.397579] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
> [ 0.397708] usb usb1: configuration #1 chosen from 1 choice
> [ 0.397735] hub 1-0:1.0: USB hub found
> [ 0.397744] hub 1-0:1.0: 6 ports detected
> [ 0.397818] alloc irq_desc for 23 on node -1
> [ 0.397820] alloc kstat_irqs on node -1
> [ 0.397826] ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low)
> -> IRQ 23
> [ 0.397849] ehci_hcd 0000:00:1d.7: setting latency timer to 64
> [ 0.397852] ehci_hcd 0000:00:1d.7: EHCI Host Controller
> [ 0.397884] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned
> bus number 2
> [ 0.397913] ehci_hcd 0000:00:1d.7: debug port 1
> [ 0.401791] ehci_hcd 0000:00:1d.7: cache line size of 32 is not
> supported
> [ 0.401942] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf2504c00
> [ 0.446413] Freeing initrd memory: 12255k freed
> [ 0.449415] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
> [ 0.449700] usb usb2: configuration #1 chosen from 1 choice
> [ 0.449741] hub 2-0:1.0: USB hub found
> [ 0.449765] hub 2-0:1.0: 6 ports detected
> [ 0.449870] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
> [ 0.449904] uhci_hcd: USB Universal Host Controller Interface driver
> [ 0.450014] uhci_hcd 0000:00:1a.0: PCI INT A -> GSI 16 (level, low)
> -> IRQ 16
> [ 0.450028] uhci_hcd 0000:00:1a.0: setting latency timer to 64
> [ 0.450033] uhci_hcd 0000:00:1a.0: UHCI Host Controller
> [ 0.450090] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned
> bus number 3
> [ 0.450144] uhci_hcd 0000:00:1a.0: irq 16, io base 0x00001800
> [ 0.450248] usb usb3: configuration #1 chosen from 1 choice
> [ 0.450272] hub 3-0:1.0: USB hub found
> [ 0.450282] hub 3-0:1.0: 2 ports detected
> [ 0.450341] alloc irq_desc for 21 on node -1
> [ 0.450343] alloc kstat_irqs on node -1
> [ 0.450352] uhci_hcd 0000:00:1a.1: PCI INT B -> GSI 21 (level, low)
> -> IRQ 21
> [ 0.450359] uhci_hcd 0000:00:1a.1: setting latency timer to 64
> [ 0.450363] uhci_hcd 0000:00:1a.1: UHCI Host Controller
> [ 0.450398] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned
> bus number 4
> [ 0.450433] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00001820
> [ 0.450550] usb usb4: configuration #1 chosen from 1 choice
> [ 0.450574] hub 4-0:1.0: USB hub found
> [ 0.450584] hub 4-0:1.0: 2 ports detected
> [ 0.450658] uhci_hcd 0000:00:1a.2: PCI INT C -> GSI 19 (level, low)
> -> IRQ 19
> [ 0.450666] uhci_hcd 0000:00:1a.2: setting latency timer to 64
> [ 0.450669] uhci_hcd 0000:00:1a.2: UHCI Host Controller
> [ 0.450703] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned
> bus number 5
> [ 0.450732] uhci_hcd 0000:00:1a.2: irq 19, io base 0x00001840
> [ 0.450823] usb usb5: configuration #1 chosen from 1 choice
> [ 0.450847] hub 5-0:1.0: USB hub found
> [ 0.450855] hub 5-0:1.0: 2 ports detected
> [ 0.450919] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low)
> -> IRQ 23
> [ 0.450927] uhci_hcd 0000:00:1d.0: setting latency timer to 64
> [ 0.450930] uhci_hcd 0000:00:1d.0: UHCI Host Controller
> [ 0.450963] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned
> bus number 6
> [ 0.450992] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00001860
> [ 0.451103] usb usb6: configuration #1 chosen from 1 choice
> [ 0.451127] hub 6-0:1.0: USB hub found
> [ 0.451137] hub 6-0:1.0: 2 ports detected
> [ 0.451194] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low)
> -> IRQ 19
> [ 0.451202] uhci_hcd 0000:00:1d.1: setting latency timer to 64
> [ 0.451206] uhci_hcd 0000:00:1d.1: UHCI Host Controller
> [ 0.451254] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned
> bus number 7
> [ 0.451281] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00001880
> [ 0.451381] usb usb7: configuration #1 chosen from 1 choice
> [ 0.451413] hub 7-0:1.0: USB hub found
> [ 0.451421] hub 7-0:1.0: 2 ports detected
> [ 0.451469] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low)
> -> IRQ 18
> [ 0.451476] uhci_hcd 0000:00:1d.2: setting latency timer to 64
> [ 0.451480] uhci_hcd 0000:00:1d.2: UHCI Host Controller
> [ 0.451512] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned
> bus number 8
> [ 0.451560] uhci_hcd 0000:00:1d.2: irq 18, io base 0x000018a0
> [ 0.451656] usb usb8: configuration #1 chosen from 1 choice
> [ 0.451687] hub 8-0:1.0: USB hub found
> [ 0.451696] hub 8-0:1.0: 2 ports detected
> [ 0.451830] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at
> 0x60,0x64 irq 1,12
> [ 0.536523] serio: i8042 KBD port at 0x60,0x64 irq 1
> [ 0.536532] serio: i8042 AUX port at 0x60,0x64 irq 12
> [ 0.536699] mice: PS/2 mouse device common for all mice
> [ 0.538918] rtc_cmos 00:05: RTC can wake from S4
> [ 0.538962] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
> [ 0.538992] rtc0: alarms up to one month, y3k, 242 bytes nvram,
> hpet irqs
> [ 0.539101] device-mapper: uevent: version 1.0.3
> [ 0.541078] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01)
> initialised: dm-devel at redhat.com <mailto:dm-devel at redhat.com>
> [ 0.541142] device-mapper: multipath: version 1.1.0 loaded
> [ 0.541145] device-mapper: multipath round-robin: version 1.0.0 loaded
> [ 0.541253] EISA: Probing bus 0 at eisa.0
> [ 0.541260] Cannot allocate resource for EISA slot 1
> [ 0.541263] Cannot allocate resource for EISA slot 2
> [ 0.541265] Cannot allocate resource for EISA slot 3
> [ 0.541267] Cannot allocate resource for EISA slot 4
> [ 0.541269] Cannot allocate resource for EISA slot 5
> [ 0.541271] Cannot allocate resource for EISA slot 6
> [ 0.541273] Cannot allocate resource for EISA slot 7
> [ 0.541279] EISA: Detected 0 cards.
> [ 0.541390] cpuidle: using governor ladder
> [ 0.541468] cpuidle: using governor menu
> [ 0.541886] TCP cubic registered
> [ 0.542021] NET: Registered protocol family 10
> [ 0.542445] lo: Disabled Privacy Extensions
> [ 0.542757] NET: Registered protocol family 17
> [ 0.543318] Using IPI No-Shortcut mode
> [ 0.543379] PM: Resume from disk failed.
> [ 0.543391] registered taskstats version 1
> [ 0.544188] Magic number: 2:740:934
> [ 0.544270] rtc_cmos 00:05: setting system clock to 2010-11-22
> 11:55:11 UTC (1290426911)
> [ 0.544273] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
> [ 0.544274] EDD information not available.
> [ 0.570173] input: AT Translated Set 2 keyboard as
> /devices/platform/i8042/serio0/input/input4
> [ 0.760080] isapnp: No Plug & Play device found
> [ 0.760094] Freeing unused kernel memory: 656k freed
> [ 0.760484] Write protecting the kernel text: 4684k
> [ 0.760531] Write protecting the kernel read-only data: 1840k
> [ 0.776785] udev: starting version 151
> [ 0.870905] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
> [ 0.870928] r8169 0000:14:00.0: PCI INT A -> GSI 19 (level, low) ->
> IRQ 19
> [ 0.870971] r8169 0000:14:00.0: setting latency timer to 64
> [ 0.871028] alloc irq_desc for 30 on node -1
> [ 0.871030] alloc kstat_irqs on node -1
> [ 0.871045] r8169 0000:14:00.0: irq 30 for MSI/MSI-X
> [ 0.871643] eth0: RTL8168c/8111c at 0xf80a0000, 00:26:22:13:ac:34,
> XID 1c4000c0 IRQ 30
> [ 0.874993] Linux agpgart interface v0.103
> [ 0.880048] b43-pci-bridge 0000:0e:00.0: PCI INT A -> GSI 18
> (level, low) -> IRQ 18
> [ 0.880067] b43-pci-bridge 0000:0e:00.0: setting latency timer to 64
> [ 0.883673] ahci 0000:00:1f.2: version 3.0
> [ 0.883687] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) ->
> IRQ 19
> [ 0.883727] alloc irq_desc for 31 on node -1
> [ 0.883729] alloc kstat_irqs on node -1
> [ 0.883741] ahci 0000:00:1f.2: irq 31 for MSI/MSI-X
> [ 0.883795] ahci: SSS flag set, parallel bus scan disabled
> [ 0.883834] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 4 ports 3
> Gbps 0x33 impl SATA mode
> [ 0.883837] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led
> clo pio slum part ccc ems
> [ 0.883842] ahci 0000:00:1f.2: setting latency timer to 64
> [ 0.893226] acpi device:01: registered as cooling_device2
> [ 0.893419] input: Video Bus as
> /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input5
> [ 0.893464] ACPI: Video Device [PEGP] (multi-head: yes rom: no
> post: no)
> [ 0.905170] scsi0 : ahci
> [ 0.905342] scsi1 : ahci
> [ 0.905426] scsi2 : ahci
> [ 0.905509] scsi3 : ahci
> [ 0.905594] scsi4 : ahci
> [ 0.905677] scsi5 : ahci
> [ 0.905721] ata1: SATA max UDMA/133 abar m2048 at 0xf2504000 port
> 0xf2504100 irq 31
> [ 0.905725] ata2: SATA max UDMA/133 abar m2048 at 0xf2504000 port
> 0xf2504180 irq 31
> [ 0.905727] ata3: DUMMY
> [ 0.905728] ata4: DUMMY
> [ 0.905731] ata5: SATA max UDMA/133 abar m2048 at 0xf2504000 port
> 0xf2504300 irq 31
> [ 0.905735] ata6: SATA max UDMA/133 abar m2048 at 0xf2504000 port
> 0xf2504380 irq 31
> [ 0.940177] ssb: Sonics Silicon Backplane found on PCI device
> 0000:0e:00.0
> [ 0.952051] usb 2-2: new high speed USB device using ehci_hcd and
> address 3
> [ 1.085011] usb 2-2: configuration #1 chosen from 1 choice
> [ 1.196073] usb 2-3: new high speed USB device using ehci_hcd and
> address 4
> [ 1.224074] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
> [ 1.231399] ata1.00: ATA-8: SAMSUNG HM320JI, 2SS00_03, max UDMA7
> [ 1.231404] ata1.00: 625142448 sectors, multi 16: LBA48 NCQ (depth
> 31/32), AA
> [ 1.238891] ata1.00: configured for UDMA/133
> [ 1.252217] scsi 0:0:0:0: Direct-Access ATA SAMSUNG
> HM320JI 2SS0 PQ: 0 ANSI: 5
> [ 1.252355] sd 0:0:0:0: Attached scsi generic sg0 type 0
> [ 1.252442] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks:
> (320 GB/298 GiB)
> [ 1.252482] sd 0:0:0:0: [sda] Write Protect is off
> [ 1.252484] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
> [ 1.252505] sd 0:0:0:0: [sda] Write cache: enabled, read cache:
> enabled, doesn't support DPO or FUA
> [ 1.252622] sda: sda1 sda2 sda3 sda4
> [ 1.293048] sd 0:0:0:0: [sda] Attached SCSI disk
> [ 1.372618] usb 2-3: configuration #1 chosen from 1 choice
> [ 1.612079] usb 3-1: new full speed USB device using uhci_hcd and
> address 2
> [ 1.784325] usb 3-1: configuration #1 chosen from 1 choice
> [ 1.976111] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
> [ 1.989068] ata2.00: ATAPI: Optiarc DVD RW AD-7560S, SX03, max UDMA/100
> [ 2.002507] ata2.00: configured for UDMA/100
> [ 2.017130] scsi 1:0:0:0: CD-ROM Optiarc DVD RW
> AD-7560S SX03 PQ: 0 ANSI: 5
> [ 2.022461] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw
> xa/form2 cdda tray
> [ 2.022466] Uniform CD-ROM driver Revision: 3.20
> [ 2.022622] sr 1:0:0:0: Attached scsi CD-ROM sr0
> [ 2.022679] sr 1:0:0:0: Attached scsi generic sg1 type 5
> [ 2.024097] usb 6-1: new low speed USB device using uhci_hcd and
> address 2
> [ 2.199213] usb 6-1: configuration #1 chosen from 1 choice
> [ 2.340102] ata5: SATA link down (SStatus 0 SControl 300)
> [ 2.676123] ata6: SATA link down (SStatus 0 SControl 300)
> [ 2.697011] usbcore: registered new interface driver hiddev
> [ 2.711448] input: Darfon USB Optical Mous as
> /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input6
> [ 2.711539] generic-usb 0003:0D62:A100.0001: input,hidraw0: USB HID
> v1.10 Mouse [Darfon USB Optical Mous] on usb-0000:00:1d.0-1/input0
> [ 2.711563] usbcore: registered new interface driver usbhid
> [ 2.711566] usbhid: v2.6:USB HID core driver
> [ 3.177677] uvesafb: NVIDIA Corporation, G98 Board - 05686e90, Chip
> Rev , OEM: NVIDIA, VBE v3.0
> [ 3.214449] uvesafb: protected mode interface info at c000:c910
> [ 3.214452] uvesafb: pmi: set display start = c00cc973, set palette
> = c00cc9ce
> [ 3.214454] uvesafb: pmi: ports = 3b4 3b5 3ba 3c0 3c1 3c4 3c5 3c6
> 3c7 3c8 3c9 3cc 3ce 3cf 3d0 3d1 3d2 3d3 3d4 3d5 3da
> [ 3.281553] uvesafb: VBIOS/hardware doesn't support DDC transfers
> [ 3.281555] uvesafb: no monitor limits have been set, default
> refresh rate will be used
> [ 3.281750] uvesafb: scrolling: ywrap using protected mode
> interface, yres_virtual=1600
> [ 3.282729] uvesafb: framebuffer at 0xcd000000, mapped to
> 0xf8200000, using 8000k, total 14336k
> [ 3.282732] fb0: VESA VGA frame buffer device
> [ 3.729853] Console: switching to colour frame buffer device 160x50
> [ 4.053631] EXT4-fs (sda1): mounted filesystem with ordered data mode
> [ 14.872727] udev: starting version 151
> [ 14.973411] vga16fb: initializing
> [ 14.973415] vga16fb: mapped to 0xc00a0000
> [ 14.973419] vga16fb: not registering due to another framebuffer present
> [ 14.980197] Adding 4882424k swap on /dev/sda2. Priority:-1
> extents:1 across:4882424k
> [ 15.043608] lp: driver loaded but no devices found
> [ 15.136206] nvidia: module license 'NVIDIA' taints kernel.
> [ 15.136210] Disabling lock debugging due to kernel taint
> [ 15.151011] type=1505 audit(1290426926.104:2):
> operation="profile_load" pid=700 name="/sbin/dhclient3"
> [ 15.151639] type=1505 audit(1290426926.104:3):
> name="/usr/lib/NetworkManager/nm-dhcp-client.action"
> [ 15.151972] type=1505 audit(1290426926.104:4):
> name="/usr/lib/connman/scripts/dhclient-script"
> [ 15.446033] sdhci: Secure Digital Host Controller Interface driver
> [ 15.446035] sdhci: Copyright(c) Pierre Ossman
> [ 15.447249] sdhci-pci 0000:1a:00.0: SDHCI controller found
> [197b:2382] (rev 0)
> [ 15.447271] sdhci-pci 0000:1a:00.0: PCI INT A -> GSI 16 (level,
> low) -> IRQ 16
> [ 15.447313] sdhci-pci 0000:1a:00.0: setting latency timer to 64
> [ 15.447346] Registered led device: mmc0::
> [ 15.447379] mmc0: SDHCI controller on PCI [0000:1a:00.0] using ADMA
> [ 15.448161] sdhci-pci 0000:1a:00.2: SDHCI controller found
> [197b:2381] (rev 0)
> [ 15.448181] sdhci-pci 0000:1a:00.2: PCI INT A -> GSI 16 (level,
> low) -> IRQ 16
> [ 15.448188] sdhci-pci 0000:1a:00.2: Refusing to bind to secondary
> interface.
> [ 15.448195] sdhci-pci 0000:1a:00.2: PCI INT A disabled
> [ 15.448970] Bluetooth: Core ver 2.15
> [ 15.449012] NET: Registered protocol family 31
> [ 15.449014] Bluetooth: HCI device and connection manager initialized
> [ 15.449016] Bluetooth: HCI socket layer initialized
> [ 15.450974] Bluetooth: Generic Bluetooth USB driver ver 0.6
> [ 15.451644] usbcore: registered new interface driver btusb
> [ 15.461463] tpm_tis 00:09: 1.2 TPM (device-id 0xB, rev-id 16)
> [ 15.482654] cfg80211: Calling CRDA to update world regulatory domain
> [ 15.511604] b43-phy0: Broadcom 4311 WLAN found (core revision 10)
> [ 15.527812] jmb38x_ms 0000:1a:00.3: PCI INT A -> GSI 16 (level,
> low) -> IRQ 16
> [ 15.527821] jmb38x_ms 0000:1a:00.3: setting latency timer to 64
> [ 15.620606] alloc irq_desc for 22 on node -1
> [ 15.620609] alloc kstat_irqs on node -1
> [ 15.620616] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level,
> low) -> IRQ 22
> [ 15.620656] HDA Intel 0000:00:1b.0: setting latency timer to 64
> [ 15.624732] phy0: Selected rate control algorithm 'minstrel'
> [ 15.625402] Registered led device: b43-phy0::tx
> [ 15.625418] Registered led device: b43-phy0::rx
> [ 15.625433] Registered led device: b43-phy0::radio
> [ 15.625490] Broadcom 43xx driver loaded [ Features: PL,
> Firmware-ID: FW13 ]
> [ 15.640927] Linux video capture interface: v2.00
> [ 15.646360] uvcvideo: Found UVC 1.00 device USB 2.0 Camera (064e:a115)
> [ 15.664573] input: USB 2.0 Camera as
> /devices/pci0000:00/0000:00:1d.7/usb2/2-3/2-3:1.0/input/input7
> [ 15.664622] usbcore: registered new interface driver uvcvideo
> [ 15.664624] USB Video Class driver (v0.1.0)
> [ 15.681829] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low)
> -> IRQ 16
> [ 15.681845] nvidia 0000:01:00.0: setting latency timer to 64
> [ 15.682019] NVRM: loading NVIDIA UNIX x86 Kernel Module 173.14.22
> Sun Nov 8 20:26:31 PST 2009
> [ 15.765402] hda_codec: ALC268: BIOS auto-probing.
> [ 15.765851] input: HDA Digital PCBeep as
> /devices/pci0000:00/0000:00:1b.0/input/input8
> [ 15.902934] cfg80211: World regulatory domain updated:
> [ 15.902937] (start_freq - end_freq @ bandwidth),
> (max_antenna_gain, max_eirp)
> [ 15.902940] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi,
> 2000 mBm)
> [ 15.902942] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi,
> 2000 mBm)
> [ 15.902945] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi,
> 2000 mBm)
> [ 15.902947] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi,
> 2000 mBm)
> [ 15.902949] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi,
> 2000 mBm)
> [ 16.592634] EXT4-fs (sda3): mounted filesystem with ordered data mode
> [ 16.672865] Synaptics Touchpad, model: 1, fw: 7.0, id: 0x1c0b1,
> caps: 0xd04711/0xa00000
> [ 16.784919] input: SynPS/2 Synaptics TouchPad as
> /devices/platform/i8042/serio1/input/input9
> [ 17.993421] EXT4-fs (sda4): mounted filesystem with ordered data mode
> [ 18.181329] type=1505 audit(1290426929.135:5):
> operation="profile_load" pid=996
> name="/usr/share/gdm/guest-session/Xsession"
> [ 18.189220] type=1505 audit(1290426929.143:6):
> operation="profile_replace" pid=997 name="/sbin/dhclient3"
> [ 18.189845] type=1505 audit(1290426929.143:7):
> [ 18.190181] type=1505 audit(1290426929.143:8):
> [ 18.193576] type=1505 audit(1290426929.147:9):
> operation="profile_load" pid=999 name="/usr/bin/evince"
> [ 18.201745] type=1505 audit(1290426929.155:10):
> operation="profile_load" pid=999 name="/usr/bin/evince-previewer"
> [ 18.206655] type=1505 audit(1290426929.159:11):
> operation="profile_load" pid=999 name="/usr/bin/evince-thumbnailer"
> [ 18.236142] b43 ssb0:0: firmware: requesting b43/ucode5.fw
> [ 18.260896] b43 ssb0:0: firmware: requesting b43/pcm5.fw
> [ 18.263044] b43 ssb0:0: firmware: requesting b43/b0g0initvals5.fw
> [ 18.267744] b43 ssb0:0: firmware: requesting b43/b0g0bsinitvals5.fw
> [ 18.388066] b43-phy0: Loading firmware version 410.2160 (2007-05-26
> 15:32:10)
> [ 18.476468] ADDRCONF(NETDEV_UP): wlan0: link is not ready
> [ 18.488531] r8169: eth0: link down
> [ 18.488703] ADDRCONF(NETDEV_UP): eth0: link is not ready
> [ 18.584189] Bluetooth: L2CAP ver 2.14
> [ 18.584194] Bluetooth: L2CAP socket layer initialized
> [ 18.594706] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
> [ 18.594710] Bluetooth: BNEP filters: protocol multicast
> [ 18.604915] Bridge firewalling registered
> [ 18.618044] Bluetooth: SCO (Voice Link) ver 0.6
> [ 18.618047] Bluetooth: SCO socket layer initialized
> [ 18.695144] ppdev: user-space parallel port driver
> [ 18.728069] Bluetooth: RFCOMM TTY layer initialized
> [ 18.728073] Bluetooth: RFCOMM socket layer initialized
> [ 18.728075] Bluetooth: RFCOMM ver 1.11
> [ 24.977053] CE: hpet increasing min_delta_ns to 15000 nsec
> [ 31.041054] CE: hpet increasing min_delta_ns to 22500 nsec
> [ 87.589113] wlan0: deauthenticating from 00:1a:3f:56:4c:04 by local
> choice (reason=3)
> [ 87.589312] wlan0: direct probe to AP 00:1a:3f:56:4c:04 (try 1)
> [ 87.592234] wlan0: direct probe responded
> [ 87.592238] wlan0: authenticate with AP 00:1a:3f:56:4c:04 (try 1)
> [ 87.594011] wlan0: authenticated
> [ 87.594030] wlan0: associate with AP 00:1a:3f:56:4c:04 (try 1)
> [ 87.596144] wlan0: RX AssocResp from 00:1a:3f:56:4c:04 (capab=0x431
> status=0 aid=2)
> [ 87.596147] wlan0: associated
> [ 87.596870] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
> [ 98.180138] wlan0: no IPv6 routers present
> [ 1159.132175] usb 1-6: new high speed USB device using ehci_hcd and
> address 3
> [ 1159.267639] usb 1-6: configuration #1 chosen from 1 choice
> [ 1159.335800] Initializing USB Mass Storage driver...
> [ 1159.336227] scsi6 : SCSI emulation for USB Mass Storage devices
> [ 1159.336374] usbcore: registered new interface driver usb-storage
> [ 1159.336379] USB Mass Storage support registered.
> [ 1159.339824] usb-storage: device found at 3
> [ 1159.339829] usb-storage: waiting for device to settle before scanning
> [ 1164.336482] usb-storage: device scan complete
> [ 1164.362239] scsi 6:0:0:0: Direct-Access HP
> v100w PMAP PQ: 0 ANSI: 0 CCS
> [ 1164.363057] sd 6:0:0:0: Attached scsi generic sg2 type 0
> [ 1168.898439] sd 6:0:0:0: [sdb] 15667200 512-byte logical blocks:
> (8.02 GB/7.47 GiB)
> [ 1168.899183] sd 6:0:0:0: [sdb] Write Protect is off
> [ 1168.899189] sd 6:0:0:0: [sdb] Mode Sense: 23 00 00 00
> [ 1168.899193] sd 6:0:0:0: [sdb] Assuming drive cache: write through
> [ 1168.903577] sd 6:0:0:0: [sdb] Assuming drive cache: write through
> [ 1168.903584] sdb: sdb1
> [ 1168.925453] sd 6:0:0:0: [sdb] Assuming drive cache: write through
> [ 1168.925461] sd 6:0:0:0: [sdb] Attached SCSI removable disk
> [ 2785.036180] usb 8-2: new full speed USB device using uhci_hcd and
> address 2
> [ 2785.191356] usb 8-2: configuration #1 chosen from 1 choice
> [ 2792.152240] hub 8-0:1.0: port 2 disabled by hub (EMI?), re-enabling...
> [ 2792.152249] usb 8-2: USB disconnect, address 2
> [ 2792.392068] usb 8-2: new full speed USB device using uhci_hcd and
> address 3
> [ 2792.456153] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 2792.834994] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 2821.740079] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 2844.876075] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 2845.408182] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 2881.464130] usb 8-2: new full speed USB device using uhci_hcd and
> address 8
> [ 2881.528188] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 2905.771423] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 3012.675498] usbcore: registered new interface driver usbserial
> [ 3012.675582] USB Serial support registered for generic
> [ 3012.676537] usbcore: registered new interface driver usbserial_generic
> [ 3012.676542] usbserial: USB Serial Driver core
> [ 3012.685503] USB Serial support registered for Garmin GPS usb/tty
> [ 3012.685545] usbcore: registered new interface driver garmin_gps
> [ 3012.685548] garmin_gps: v0.33:garmin gps driver
> [ 3023.880084] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 3986.388032] usb 8-2: new full speed USB device using uhci_hcd and
> address 11
> [ 3986.452087] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4097.800203] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4098.552130] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4099.048474] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4099.296191] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4100.288185] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4140.804173] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4144.512257] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4144.928172] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4156.724167] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4164.148184] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4164.768211] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4172.908198] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4182.760201] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4183.865195] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4186.636176] usb 8-2: new full speed USB device using uhci_hcd and
> address 26
> [ 4186.700193] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4187.088076] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4191.984211] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4193.868186] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4194.280253] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4196.308272] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4198.396089] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4200.844185] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4218.408201] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4221.176204] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4226.684123] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4227.264081] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4228.008192] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4228.256120] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4229.248165] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4229.496183] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4229.744098] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4229.992202] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4264.892208] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4275.704169] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4276.120192] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4277.112180] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4277.608189] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4277.856149] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4278.108194] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4278.352105] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4278.600164] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4279.344147] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4282.508164] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4285.432153] usb 8-2: new full speed USB device using uhci_hcd and
> address 55
> [ 4285.496119] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4293.508107] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4294.224211] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4294.720107] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4295.216187] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4296.704154] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4297.200172] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4299.776183] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4301.277091] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4304.284169] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4306.044089] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4306.376118] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4306.872095] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4310.008189] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4312.040104] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4312.576167] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4313.320182] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4314.840112] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4315.552899] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4317.176185] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4317.536141] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4319.604179] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4321.940173] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4322.248144] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4322.744182] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4323.488091] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4323.736083] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4323.984166] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4324.232170] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4324.480165] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4324.728155] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4324.976184] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4325.224169] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4325.472089] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4325.720165] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4326.216160] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4326.712176] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4330.560202] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4330.928139] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4331.424177] hub 8-0:1.0: unable to enumerate USB device on port 2
> [ 4332.664159] hub 8-0:1.0: unable to enumerate USB device on port 2
> arthur at rgsg:~$
> Is the last news.....
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101122/a99bbef1/attachment.html>
