[Qgis-user] Re: WPS client plugin on ubuntu 10.04
Michele Beneventi
mbeneventi at gmail.com
Tue Nov 30 01:59:50 PST 2010
Hi Jürgen,
Thanks a lot.
Installing python-qt4-sql everything works fine.
Now I'm trying to connect to my geoserver WPS service. I am able to
connect and see the capabilities but nothing else: in the WPS plugin
form there is not place to sign the WFS layer name that I previously
catalogued as WFS layer (from postgis datastore) and load in the QGIS
ToC.
Is this procedure right?
Michele
On Tue, Nov 30, 2010 at 10:13 AM, Jürgen E. <jef at norbit.de> wrote:
> Hi Michele,
> On Tue, 30. Nov 2010 at 09:36:55 +0100, Michele Beneventi wrote:
>> I've already installed "libqt4-sql" without problem as you advise me,
>> but never is changed.
> Did you also install python-qt4-sql?
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
