[Qgis-user] Re: WPS client plugin on ubuntu 10.04
Michele Beneventi
mbeneventi at gmail.com
Tue Nov 30 04:52:47 PST 2010
Hi Horst,
you're completely right, but in the GUI (e.g.
gt:BufferFeatureColletion) I can see all the option but I am not able
to select and choose nothing but the buffer value.
As I see geoserver WPS plugin is a prototype, perhaps there could be
something wrong in it.
...the test continue....
thanks a lot
Michele
Michele Beneventi
GIS Technologist
LAT: 39° 18' 25"; LONG: 08 °33' 20"
http://www.michelebeneventi.it/
http://it.linkedin.com/in/michelebeneventi
On Tue, Nov 30, 2010 at 12:03 PM, Düster Horst <Horst.Duester at bd.so.ch> wrote:
> Hi Michele
> After you have loaded the capabilities of your WPS you have to select a
> process and click OK. A GUI should appear depending on the inputs of the
> process with all input options.
> Horst
> Dr. Horst Düster
> Stv. Amtschef / kantonaler GIS-Koordinator
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Mobil ++41(0)79 511 54 12
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> -----Ursprüngliche Nachricht-----
> Von: Michele Beneventi [mailto:mbeneventi at gmail.com]
> Gesendet am: Dienstag, 30. November 2010 11:00
> An: Jürgen E.; qgis-user at lists.osgeo.org
> Betreff: [Qgis-user] Re: WPS client plugin on ubuntu 10.04
> Hi Jürgen,
> Thanks a lot.
> Installing python-qt4-sql everything works fine.
> Now I'm trying to connect to my geoserver WPS service. I am able to
> connect and see the capabilities but nothing else: in the WPS plugin
> form there is not place to sign the WFS layer name that I previously
> catalogued as WFS layer (from postgis datastore) and load in the QGIS
> ToC.
> Is this procedure right?
> Michele
> On Tue, Nov 30, 2010 at 10:13 AM, Jürgen E. <jef at norbit.de> wrote:
>> Hi Michele,
>> On Tue, 30. Nov 2010 at 09:36:55 +0100, Michele Beneventi wrote:
>>> I've already installed "libqt4-sql" without problem as you advise me,
>>> but never is changed.
>> Did you also install python-qt4-sql?
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel.
>> +49-4931-918175-20
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>> +49-4931-918175-50
>> Software Engineer D-26506 Norden
>> http://www.norbit.de
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
