[Qgis-user] ValueTool: wrong ordering of layers in vrt files
Agustin Lobo
alobolistas at gmail.com
Wed Oct 6 13:31:57 PDT 2010
Ghislain,
The ordering is correct now, but now the graph does not work, as it
says need Qwt
(in windows standalone 1.5)
Are you using a newer Qwt than the one distributed within the standalone?
Could you go back to the one you were using?
Thanks
Agus
2010/10/6 Ghislain Picard <ghislain.picard at lgge.obs.ujf-grenoble.fr>:
> Thanks for reporting this bug. It should be solved now, please update the
> plugin in your QGis.
> Ghislain
> On 10/06/2010 05:13 PM, Agustin Lobo wrote:
>> Hi!
>> I've just found that the Value Tool shows the layer info for raster
>> layers in VRT files
>> in a wrong order, please see the jpg
>> https://sites.google.com/site/openfiles2/home/errorValueToolOrdering.jpg
>> I've also put there the vrt file, so that you can check that the order
>> in the file is correct:
>> https://sites.google.com/site/openfiles2/home/AFNDVI.vrt
>> This is a problem for the graph display: as we use it for time series
>> of NDVI, the profiles are wrong.
>> Any hope this problem will have a fix? Should I fill a ticket?
>> Thanks
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
