[Qgis-user] INTERLIS plugin on mac
William Kyngesburye
woklist at kyngchaos.com
Fri Oct 8 10:04:10 PDT 2010
On Oct 8, 2010, at 11:32 AM, Annina Hirschi Wyss wrote:
> Hi List,
> I can't get the INTERLIS plugin to work on my OSX 10.6.4, QGIS 1.5.0 (Framework install from KyngChaos). It says it can't find the JRE, so I set the JAVA_HOME variable and path, but no change...
> Am I missing something, or did someone make similar experiences?
Do you need model support? From what the dialog says for loading Interlis data, Java is needed for model support, implying that will still read interlis data without it.
Adding the JRE path to the environment is yet another case where OS X applications do not get any of the shell environment (ie set in your .bash_profile). There is a hidden, little documented (if at all) method to get environment into an application, but I don't like to encourage it because it's clunky to use (hidden file, and no GUI unless you install 3rd party software).
I think Qgis needs a way to add arbitrary variables to its environment (or at least well known ones), otherwise individual plugins need to have a configuration to set these things, which many developers don't think about.
> Thank's for any hint
> Annina_______________________________________________
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
