[Qgis-user] CSWclient is available
Alexander Bruy
alexander.bruy at gmail.com
Tue Oct 19 03:00:41 PDT 2010
Hi Paolo,
thanks for feedback
19 октября 2010 г. 11:26 пользователь Paolo Cavallini
<cavallini at faunalia.it> написал:
> Hi.
> I'm getting an error from one of the default servers (PortalU Catalog Server):
> Error getting server response:
> Document is XML, but not CSW-ish
Seems server response is not fully compatible with OGC spec or invalid.
19 октября 2010 г. 11:37 пользователь Paolo Cavallini
> In fact I also get:
> <?xml version="1.0" encoding="UTF-8"?>
> <ServiceExceptionReport xmlns="http://www.opengis.net/ogc" version="1.2.0">
> <ServiceException code="InvalidParameterValue" locator="outputSchema">Attribute
> 'outputSchema' is invalid.</ServiceException>
> </ServiceExceptionReport>
> With another server (Alterra CSW), when asking Metadata
This seems to be a problem with the CSW implementation too. Server not
taking valid
parameters (which itself advertises in Capabilities XML).
I'll remove this servers from default list.
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/paolo/.qgis/python/plugins/cswclient/cswclientdialog.py", line 692, in
> showMetadata
> dlg.textXML.document().setDefaultStyleSheet( myStyle )
> AttributeError: 'CSWResponseDialog' object has no attribute 'textXML'
This should be fixed in 0.0.8
Alexander Bruy
