AW: Re: Fwd: [Qgis-user] QGIS "Near"
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Wed Oct 20 11:54:12 PDT 2010
Hi Zoran
I had some time left, took all my code snippets and also the one from
Carson. Please try the plugin "Nearest" that should cover your example
1:
http://www.catais.org/qgis/plugins.xml
regards
Stefan
-----Ursprüngliche Nachricht-----
Von: Zoran Jankovic [mailto:zoran.jankovic at zisis.hr]
Gesendet am: Mittwoch, 20. Oktober 2010 19:21
An: qgis-user
Betreff: Re: Fwd: [Qgis-user] QGIS "Near"
Hi Joe,
On Wed, Oct 20, 2010 at 5:06 PM, Joe Larson < joelarso at gmail.com>
wrote:
Does the function 'snapWithContext'
http://doc.qgis.org/head/classQgsVectorLayer.html#733b974dce13d587
e05cf3d4fc24f208
which "Snaps to segment or vertex within given tolerance." seem
like
what you're looking for? I came across it while trying to get
Quantum
Navigator working recently...seemed relative, but I'm no expert!
This is similar to the mentioned solution with selecting by radius,
or changing the tolerance of ID tool. Close, but no cigar. Since this
is not very urgent, I've decided to continue pursuing that outlined
solution Carson gave, and write a plugin i Python based on that.
Since I actually never used Python before, it may take a while, but
hey, I get to learn sth. new :-).
I never got the word back from Carson, has he developed anything
along these lines, but I have to presume he didn't...
Anyone interested in joning me, or even earning some money, is still
invited to jump on board. My GIS implementation project is well on
the way, and it seems there'll even be some money involved :-).
Zoran
~joe
On Tue, Oct 19, 2010 at 9:55 AM, Andreas Neumann <a.neumann at
carto.net>wrote:
> Hi Zoran,
> I believe the infrastructure of what you want is already wihtin
the
> selection and identify tools in QGIS. Isn't this almost
implemented in the
> current identify tool?
It sort of is, but not completely. Identify will ID all the
features within
certain radios (percentage of extent), but it will ID _all_ of the
features
within this radius. I only need the nearest, no matter how far
away... Let
us say it is, for simplicity, within current extent.
> The current identify tool selects "near" or "close by" features
within a
> certain tolerance. This tolerance can be set in "Options" -->
"Map tools"
> "search radius". I believe it currently only effects the
identify tool. Do
> you want the same tolerance also be used for the click-selection
tool?
Look above. This could be useful, but it is not the functionality
I'm
currently looking after.
> Are you also aware that in QGIS 1.6 there are new selection
tools?
> * by click
> * by rectangle
> * by polygon
> * by freehand
> * by radius
Yup, these are great, but they all select _multiple_ features
within radius,
rectangle, etc.
> Maybe this also helps to address your needs?
> Of course you can combine it with previous selections by
pressing the ctrl
> key.
BR,
Zoran Jankovic
ZIS-Izrada softvera i savjetovanje / ZIS - Software Development
and
Consulting
http://www.zisis.hr
M: 00 385 98 682 902
T: 00 385 44 683 374
A. Senoe 4
44320 Kutina
Croatia
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101020/62fce3ce/attachment.html>
