[Qgis-user] Re: comments on qgis-grass plugin?
Ricardo Filipe Soares Garcia da ricardo.garcia.silva at gmail.com
Thu Oct 21 02:11:22 PDT 2010
Hi Tim
> BUT:
> The process boxes (e.g. a operator rectangle) keep sticking at the
> mouse. once the box is placed, i cannot change the cursor function to
> connect the boxes.
Try this:
-After placing your desired process box, select the 'Add connection'
icon in the module's toolbar (its the one that looks like a line with
red and green circles at the edges)
- You'll notice that the mouse cursor has now changed to display a crosshair
- You can now connect your process boxes. Be sure to start drawing the
connections by the boxe's red circle markers (the markers will become
gray if the connection is successful)
- If you make a mistake just select the 'select item' icon in the
toolbar (it looks like a mouse pointer inside a rectangle), then click
on your connection line and press the delete key or the 'delete item'
icon on the toolbar
Cheers
___________________________ ___ __
Ricardo Garcia Silva
