[Qgis-user] (Interpolate Plugin) Is it possible to set the opacity of grids which contain no points to 0%?
Micha Silver
micha at arava.co.il
Sat Oct 30 03:23:22 PDT 2010
On 10/29/2010 11:26 PM, Ryan Michael wrote:
> I have a data set that I'm trying to interpolate, and in some cases
> there are large swaths of area that are surrounded by points, but
> don't contain any points. This produces a graph where these interior
> regions have values determined by the nearest points.
> Rather than assuming that these points are accurately represented by
> the surrounding points, I would prefer to not render those grid
> points, and only show grid boxes which are actually representative of
> data. Is there a way to do this? I was thinking I could add second
> field and assign opacity to that, but I can't figure out a way to get
> the field to be 'true' if there are points enclosed and 'false'
> otherwise (or to simply count the number of enclosed points.)
> Any ideas?
Just a thought- You might create a buffer around all points at the max
distance you consider to be relevant for interpolation. The buffer will
thus cover only areas with a density of points of your choosing. The
"swaths" will be outside the buffer. Convert the buffer to a raster, and
make it a MASK. Now, after doing your point interpolation, use the mask
to set to null all the areas outside the buffer.
> Thanks for any suggestions!
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101030/fdb061bc/attachment.html>
