[Qgis-user] gdalbuildvrt crashes with large number of images (Was: How do you deal with lots of raster data?)
Alister Hood
alister.hood at synergine.com
Wed Sep 1 18:13:27 PDT 2010
Thanks,
I probably should have figured out that vrt is what I was after.
Now I have a problem:
I can create a vrt with only a small number of images using QGIS from the standalone 1.5.0 Windows installer (QGIS from the osgeo installer refuses to accept .ecw images). But if I try to create one with all the files I get this crash fairly quickly:
gdalbuildvrt.exe - Application Error
The instruction at "0x7c9369da" referenced memory at "0x0000000". The memory could not be "read".
Has anyone else experienced a similar problem?
-----Original Message-----
From: maning sambale [mailto:emmanuel.sambale at gmail.com]
Sent: Wednesday, 1 September 2010 9:01 p.m.
To: Alister Hood
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] How do you deal with lots of raster data?
two options:
- gdal's Virtual Raster Format (vrt) - you can create vrt files using
the Raster Tools plugin
- RasterLite - looks promising but not using it at the moment
On Wed, Sep 1, 2010 at 4:44 PM, Alister Hood <alister.hood at synergine.com> wrote:
> Hi everyone,
> I'm looking for insight into dealing with large amounts of raster data in
> QGIS; at the moment I'm really interested in just displaying background
> images, not doing raster analysis.
> Trying to add several hundred ecw images takes an extremely long time and a
> lot of memory. I thought QGIS might establish the location of each image
> but only load images that are visible in the map extents (and maybe adjacent
> images, to speed up panning and zooming). However it seems like it must be
> loading all of the images. Is that right?
> Would it be better for me to install some sort of tile server that I can
> load the images into and connect QGIS to? How do other people deal with
> large amounts of raster data?
> Thanks,
> Alister
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
