[Qgis-user] Re: Raster layer display control from Plugin
    JP Glutting
    jpglutting at gmail.com
    Thu Sep  2 22:50:34 PDT 2010
Although here (http://blog.qgis.org/node/94) it seems to indicate that
SingleBandPseudoColor is a constant:
mypLayer->setColorRampingType(QgsRasterLayer::BLUE_GREEN_RED);
  mypLayer->setDrawingStyle(QgsRasterLayer::SINGLE_BAND_PSEUDO_COLOR);
  std::deque myLayerSet;
which is what I was thinking in the first place, and here (
http://doc.qgis.org/stable/classQgsRasterLayer.html#36796f1a303dac9848ba3dce3e5527dc7b7c9814c053986846b579119d2e5be9
DrawingStyle is described as an enumerator, which seems coherent. I am not
sure how to do this from Python.
Cheers,
JP
On Fri, Sep 3, 2010 at 7:43 AM, JP Glutting <jpglutting at gmail.com> wrote:
> Actually, I am not even sure that first part is the way to do it. I tried
> this:
>  resultsLayer.setDrawingStyle(QtCore.QString('SingleBandPseudoColor'))
>         resultsLayer.setCacheImage(None)
>         resultsLayer.triggerRepaint()
> (passing the 'SingleBandPseudoColor' style as a string) and it makes the
> raster invisible. It still shows up black in the Layers Panel, but it
> doesn't show in the main window until you change the properties manually
> (and it is Grayscale when you do). It feels like I am pretty close, but I am
> not sure how to interpret this code from the QGIS documentation:
> myRasterLayer->setDrawingStyle<http://classQgsRasterLayer.html#3a923f732bedd87d0b920c5552215434>
> (QgsRasterLayer::SingleBandPseudoColor<http://classQgsRasterLayer.html#36796f1a303dac9848ba3dce3e5527dc7b7c9814c053986846b579119d2e5be9>
> (I never learned more than the basics of C++, and that was a long time
> ago). The source code seems to indicate that the format needs to be passed
> as a string (of course, when the layer is generated):
> 00204     QgsRasterLayer <http://classQgsRasterLayer.html>( int dummy,00205                     const QString & baseName = QString(),00206                     const QString & path = QString(),00207                     const QString & providerLib = QString(),00208                     const QStringList & layers = QStringList(),00209                     const QStringList & styles = QStringList(),00210                     const QString & format = QString(),
> 00211 const QString & crs = QString() );
> Thanks,
> JP
> On Fri, Sep 3, 2010 at 3:04 AM, JP Glutting <jpglutting at gmail.com> wrote:
>> Hello,
>> I am working on a plugin (I mentioned it on the list earlier, but it isn't
>> relevant to the question I have now). I have the results written to a raster
>> file, and I need to display it. I am using this code:
>>         resultsLayer = qgis.core.QgsRasterLayer(self.query.results_file,
>> QtCore.QFileInfo(self.query.results_file).baseName())
>>         qgis.core.QgsMapLayerRegistry.instance().addMapLayer(resultsLayer)
>> which works fine for opening the file, but I would like to fine-tune the
>> display so the user doesn't have to reset the properties (in my test exaple
>> the values are 0 and 1 and the display is essentially all black). I would
>> like to either display the results in pseudocolor directly, or in grayscale
>> with the scale stretched to the min and max extent of the raster.
>> I tried the psuedocolor with this code:
>>  resultsLayer.setDrawingStyle(qgis.core.QgsRasterLayer.SingleBandPseudoColor)
>> which doesn't seem to do anything at all, and I am just guessing, really.
>> I found a nice tutorial about how to calculate the min and max extent of a
>> raster and adjust the display here:
>> http://linfiniti.com/2010/08/a-simple-qgis-python-tutorial/
>> and I tried the following code:
>>         band = resultsLayer.bandNumber(resultsLayer.grayBandName())
>>         extentMin = 0.0
>>         extentMax = 0.0
>>         generateLookupTableFlag = False
>>         extentMin, extentMax =
>> resultsLayer.computeMinimumMaximumFromLastExtent(band)
>>         resultsLayer.setMinimumValue(band, extentMin,
>> generateLookupTableFlag)
>>         resultsLayer.setMaximumValue(band, extentMax,
>>         resultsLayer.setStandardDeviations(0.0)
>>         resultsLayer.setUserDefinedGrayMinimumMaximum( True )
>> but that fails with the following error:
>> Traceback (most recent call last):
>>   File "/Users//.qgis/python/plugins/mcelite/MCELiteDialog.py", line 361,
>> in accept
>> TypeError: 'float' object is not iterable
>> and I don't understand what the float object is, exactly.
>> Any help or suggestions much appreciated.
>> Cheers,
>> JP
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100903/51660928/attachment.html>
