[Qgis-user] Sort table by column on composer
Stefan Kiefer
st_kiefer at web.de
Thu Sep 2 23:14:37 PDT 2010
Hi Pedro,
sorry I overlooked that. Whatsoever, as far as I see there is no way to
do that yet. I suggest to issue a ticket with this feature, it would be
a worthy enhancement, particularly because there is only a limited
number of rows to display. You can submit a ticket under:
https://trac.osgeo.org/qgis
I believe Marco Hugentobler is responsible for the composer attribute
table.
cheers
Stefan
Am Donnerstag, den 02.09.2010, 14:52 -0700 schrieb Pedro Venâncio:
> Hello Stefan,
> I'm talking about the tables placed in the layout with adds attribute
> table tool, in the print composer.
> Thanks,
> Pedro
> --- On Thu, 9/2/10, Stefan Kiefer wrote:
> Hi Pedro,
> you can sort a table by simply clicking on the header of a
> column. You
> can switch the order down/top - top/down by clicking again.
> cheers
> Stefan
> Am Mittwoch, den 01.09.2010, 06:15 -0700 schrieb Pedro
> Venâncio:
> > Hello,
> > It´s possible to sort the table generated by Adds Atribute
> Table of
> > Composer?
> > When I insert the table, it is placed in the order in which
> attributes
> > were inserted into the shapefile. However, I would like to
> sort the
> > table alphabetically by one of the fields.
> > Thanks,
> > Pedro Venâncio
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100903/972dbe70/attachment.html>
