AW: [Qgis-user] Python not loaded on startup
Möri Cedric Cedric.Moeri at bd.so.ch
Wed Sep 8 05:58:07 PDT 2010
Hi Jürgen
> Did you rebuild after removing?
Yes, I did a make clean and then a new build.
>No, I meant installing qgis from nightly builds.  That might give some further
>insight.
I install from trunk, my current revision is 14202.
regards
Cédric
mit freundlichen Grüssen
Cédric Möri
GIS-Informatiker
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon: +41 (0)32 627 24 75
Telefax: +41 (0)32 627 22 14
mailto:cedric.moeri at bd.so.ch
http://www.agi.so.ch
----- Originalnachricht -----
Von: "Jürgen E. Fischer" <jef at norbit.de>
Gesendet: Mit, 8.9.2010 14:10
An: qgis-user at lists.osgeo.org
Betreff: Re: [Qgis-user] Python not loaded on startup
Hi Cédric,
On Wed, 08. Sep 2010 at 13:53:38 +0200, Möri Cedric wrote:
> I install with a prefix: /usr/local/qgis. In this prefix there are no old
> qgis-libs. I found some old qgis-libs in /usr/local/lib and /usr/lib from a
> former install out of a package and removed them now, but no effect :-(
> About the nightly builds: do you mean to update the sip stuff with nightly builds?
insight.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
