[Qgis-user] Save group layers in Quantum GIS 1.5?
    Richard Duivenvoorde
    rdmailings at duif.net
    Wed Sep  8 08:42:25 PDT 2010
Hi Els,
in addtion of the answers others gave earlier.
there is a python plugin called 'MultiQml', with which you can tell QGIS
to use one qml/style file for several different layers. This works if
you have a lot of layers which use the exact same symbology: you can
style them in one go.
another option maybe? To start with a 'base'-project, save that to a
project file, and use that project as a starting project for other
projects in which you can then load additional data. After
loading/symbolisation you can save the project via 'Save As' to a
different name.
Hope this helps,
Els Dens wrote:
> Is it possible in QGIS 1.5 to save a combination of vector and raster layers to a kind of 'layer file', in order to be able to load this combination of layers into a new project (saving also the previously defined symbology and labeling, ...)?
> I give an example of a combination of vector and raster layers in the screenshot below. I would like to save this combination of layers to be able to use it in my later projects too.
> [cid:image001.png at 01CB4F4A.B2459570]
> Thank you for the information!
> Els
> Aan dit bericht kunnen geen rechten worden ontleend. Alle berichten naar dit professioneel e-mailadres kunnen door de werkgever gelezen worden.
> Ondernemingsnummer: 0253.973.219
> Qgis-user mailing list
