[Qgis-user] How to capture a polygon for a non-spatial feature
Jeremy Palmer
JPalmer at linz.govt.nz
Fri Sep 10 21:21:38 PDT 2010
How do you capture a polygon (or any geometry type) for a feature in the attribute table that does not have an existing geometry?
I tried selecting the geometry in the attribute table then creating a polygon with the capture polygon tool, however it only brings up a dialog for a new feature.
Thanks,
Jeremy
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100911/fdcd7ef3/attachment.html>
