[Qgis-user] gdal_merge - GDAL Tools plugin Qgis error message
William Kyngesburye
woklist at kyngchaos.com
Tue Sep 14 08:13:21 PDT 2010
On Sep 14, 2010, at 9:55 AM, sergio sevillano wrote:
> El 14/09/2010, a las 14:52, William Kyngesburye escribió:
>> Are you using the standalone Qgis?
> i have installed frameworks and qgis manually from
> http://www.kyngchaos.com/software/qgis
> but not sure if its standalone or not
> is there a way i can check?
Only by size (Get Info): standalone is about 290+MB installed, standard is about 214MB.
>> What other GDAL tools have you used that work, besides gdal_contour? gdal_merge itself is a python program, while gdal_contour is a binary. It seems that an external python script is having problems finding python
> other .py won´t work either
I get this also. I'm using the standard Qgis.
My guess is that external python scripts aren't getting a shell environment so they can't find python, even though Qgis extensions run thru python. Those GDAL python scripts all have the standard shebang:
#!/usr/bin/env python
Someone with a better understanding of this needs to comment so I can try to figure out why the Mac build is not working (while from lack of reported problems it seems other systems work).
>> On Sep 14, 2010, at 5:59 AM, sergio sevillano wrote:
>>> hi
>>> i get an
>>> "env: python: No such file or directory"
>>> error when i try to use GDAL Tools plugin to merge some .hgt images
>>> seems to me as a path thing
>>> but other gdal plugins work fine
>>> as gdal_contours
>>> any hint or place to look further?
>>> thanks
>>> sergio
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
