[Qgis-user] autostyles for PostGIS
    Jürgen E. Fischer
    jef at norbit.de
    Sat Sep 18 07:20:31 PDT 2010
Hi Paolo,
On Wed, 15. Sep 2010 at 18:51:43 +0200, Paolo Cavallini wrote:
> If we save a file in the same folder and with the same name as a vector
> layer, that style is used automagically every time the layer is opened (which
> is good).
Or if you just click "Save As Default".  That also works for PostGIS layers, in
that case the defaults are saved to your ~/.qgis/qgis.qmldb.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
