[Qgis-user] Plugins SDA4PP, GDAL and Home Range
Paolo Cavallini
cavallini at faunalia.it
Sat Sep 18 23:20:52 PDT 2010
Il 18/09/2010 23:04, Manuel SpĂnola ha scritto:
> I am running QGIS 1.5.0 Tethys (Spanish version) in Windows XP.
> I would like to install the plugins:
> SDA4PP, GDAL and Home Range.
You should:
- open the Plugin Installer
- add 3rd party repos
- select and install the plugins you need.
Beware: you have to install R libraries to have SDA4PP and Home Range plugin to work.
I understand there may be problem with paths in Windows, so you have to add the paths
to your R installation manually.
If you need help for this, please let us know.
> There is one gdal tools installed but I don't see it in the plugins menu.
It has his own menu (Raster).
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
