[Qgis-user] Re: Projection of Shapefile export
Ken Norris
ken.norris at wideband.net.au
Thu Sep 23 14:27:15 PDT 2010
Roland,
I incorporated your srs.db but the translation falls about 30m short (in
Melbourne) and about the same distance out at a control point in southern
Tasmania.
I see you use the National parameters that '... have an estimated accuracy
of about 1 metre.' and are most accurate around Canberra (surprise).
Geoscience recommend use of their distortion tables (xxx.gsb) for more
accurate work Australia-wide.
Can you incorporate the parameter reference to the distortion tables in the
srs.db? I, like Brett, am out of my depth here.
Regards
Ken
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Projection-of-Shapefile-export-tp5536736p5564786.html
Sent from the qgis-user mailing list archive at Nabble.com.
