Re[2]: [Qgis-user] Re: 2 Questions on Road-Graph plugin
Sergey Yakushev yakushevs at list.ru
Thu Apr 7 21:00:00 PDT 2011
Ок. I understand you.
If source layer and map canvas has different CRS and 'on the fly' CRS transformation set to OFF then plugin not working.
Thanks for testing. I will be fix it in some days.
Thu, 7 Apr 2011 14:41:15 -0300 письмо от Mario Román <mromantree at gmail.com>:
> Sergey:
> Sorry by the confussion. (I´m a complete animal ) Is *not* working just in *
> 1.6* version
> The error message in Trunk is another one, related with the projection
> inconsistence between project and layer
> Mario
> 2011/4/6 Mario Román <mromantree at gmail.com>
> > Hi, thanks by your answer
> > 2011/4/6 Sergey Yakushev <yakushevs at list.ru>
> >> Hello
> >> > Start point doesn't tie to the road!
> >> > That could happen when using an "on the fly projected layer" , no it`s
> >> > original one
> >> What version of QGIS are you using? In the trunk this not should be.
> > >It has happened in 1.6 Copiapo. And in the Trunk but *intentionally*tested.
> When the default projection is different to the layer >projection
> >> > It is planned to include "salesman trouble" through this same plugin ?
> >> Yes, but not soon :-)
> > > What a date are you thinking about ?
> >> > Excellent job
> >> Thanks
> > > is really a very good job
С уважением Якушев Сергей yakushevs at list.ru
