[Qgis-user] request/feature for georeferencer: setting band combinations
maning sambale
emmanuel.sambale at gmail.com
Fri Apr 8 01:54:30 PDT 2011
We have pngs images that has an Alpha channel that requires
rectification. Using the georeferencer plugin, the image look odd
because it combines b1,b4,b3 in the RGB layers. B4 is the alpha band.
Would it be possible to select which band to display using the
georeferencer plugin?
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
