[Qgis-user] Understanding the rule-based renderer
Andreas Neumann
a.neumann at carto.net
Fri Apr 8 04:03:42 PDT 2011
Hi Martin,
Thank you for the explanation. I believe that a) option is more natural
to users. But of course we would also need a way to later change the
order of the rules - once they are created.
For now I am just using additional layers until the rule-based renderer
behaves like a) or SLD.
Thanks,
Andreas
On Fri, 8 Apr 2011 12:25:03 +0200, Martin Dobias wrote:
> On Fri, Apr 8, 2011 at 11:36 AM, Andreas Neumann
> <a.neumann at carto.net> wrote:
>> Hi,
>> I am trying to better understand the rule based renderer.
>> Which version is correct?
>> a) QGIS is rendering all features of the first rule, then the second
>> rule,
>> etc, Features of the first rule are rendered first, features of the
>> second
>> rule on top of features from the first rule
>> b) QGIS is rendering each feature on by one and decides which rule
>> applies.
>> I hope it is not version b), I hoped it behaves like version a) but
>> it
>> behaves a bit odd with my data. For my data it seems like the order
>> of the
>> rule has no influence on the rendering order ;-(
> Hi Andreas
> the rule based renderer uses the b) option: it goes through the
> features one by one and applies all matching rules (in the order in
> which they appear). Mayeul Kaufmann has done some work in order to
> support option a) by implementing support for symbol levels so that
> the rendering order can be overridden.
> My ultimate goal is to only support the option a) in a way how SLD
> specifies it: rules are grouped and these groups are rendered one
> after each other.
> Regards
> Martin
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
