[Qgis-user] Rule renders and colour ramps
Ramon Andinach
custard at westnet.com.au
Fri Apr 8 16:51:33 PDT 2011
On a related thought to the recent questions about rule renders. Mostly I'm using the rules to define colour schemes that I can't work out how to get otherwise.
Is there a way to define custom colour ramps?
Particularly I'm thinking of colour brewer ramps.
If there is, could someone point me in the right direction?
If there was, then I could use that ramp across a different fields and in different files more easily than a rule render, which I have to edit every time I load it up for a different field.
So say, I have point data for gold, arsenic and copper in one file. If I use one colour scheme for all of them, then other people can look and see that this colour is the good results. If I have a suitable ramp, I can just select the field and categorise. The rule, I have to load up, alter each rule for the field each time I want to look at a different field.
Hopefully that makes sense.
-ramon.
