[Qgis-user] No geometry for sql server
Yves Jacolin
yjacolin at free.fr
Tue Apr 12 04:18:29 PDT 2011
Christophe,
could you test ogr directly to connect to your SQL Server? For example convert
sql server layer into shapefile. You will know if this is an ogr or QGIS issue.
Y.
Le mardi 12 avril 2011 12:39:21, Nathan Woodrow a écrit :
> This seems to be a bug, I have noticed it is happens mainly on Windows XP
> but Windows 7 also has this bug. I'm not sure where the problem is, I
> suspect QGIS as OGR via command line returns the correct objects.
> - Nathan
> On Tue, Apr 12, 2011 at 8:16 PM, Christophe B <ampouillle at gmail.com> wrote:
> > Hello List,
> > I now test the ability to connect to SQL Server data whis GDAL 1.8 of
> > QGIS 1.7.
> > The connection is correct but I have no geometry in return, and the right
> > attribute data (error).
> > Is a problem in GDAL / OGR? or QGIS 1.7?
> > Should we open a new ticket ?
> > Thank you in advance
> > Christophe Baume
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Yves Jacolin
http://yjacolin.gloobe.org
