[Qgis-user] No geometry for sql server
Nathan Woodrow madmanwoo at gmail.com
Wed Apr 13 01:23:20 PDT 2011
The issue is not with the python code itself but rather something in the
qgis code for the ogr provider.  I know there is a bug there I'm just having
trouble tracking down what it is.
On Wed, Apr 13, 2011 at 6:07 PM, Yves Jacolin <yjacolin at free.fr> wrote:
> Christophe,
> Why do you say the issue come from the python code? Your example shows
> nothing
> What is the result of your last command?
> Y.
> Le mercredi 13 avril 2011 09:49:04, Christophe B a écrit :
> > Hello Yves,
> > I tried to convert my table to a shapfile with ogr2ogr (GDAL 1.8.0,
> > released 2011/01/02) and it works : my shapfile has geometry and
> attribute
> > data. It is therefore a problem whis python code !
> > >>> conn_string ="MSSQL:server=.\SQLEXPRESS;
> database=ObservatoireCommerce;tables=dbo.T_CommuneGeographie;trusted_connec
> > tion=yes"
> > >>> qgis.utils.iface.addVectorLayer(conn_string,'test','ogr')
> > 2011/4/12 Yves Jacolin <yjacolin at free.fr>
> > > Christophe,
> > > could you test ogr directly to connect to your SQL Server? For example
> > > convert
> > > sql server layer into shapefile. You will know if this is an ogr or
> QGIS
> > > issue.
> > > Y.
> > > Le mardi 12 avril 2011 12:39:21, Nathan Woodrow a écrit :
> > > > This seems to be a bug, I have noticed it is happens mainly on
>  Windows
> > > XP
> > > > but Windows 7 also has this bug.  I'm not sure where the problem is,
> I
> > > > suspect QGIS as OGR via command line returns the correct objects.
> > > > - Nathan
> > > > On Tue, Apr 12, 2011 at 8:16 PM, Christophe B <ampouillle at gmail.com>
> > > wrote:
> > > > > Hello List,
> > > > > I now test the ability to connect to SQL Server data whis GDAL 1.8
> of
> > > > > QGIS 1.7.
> > > > > The connection is correct but I have no geometry in return, and the
> > > right
> > > > > attribute data (error).
> > > > > Is a problem in GDAL / OGR? or QGIS 1.7?
> > > > > Should we open a new ticket ?
> > > > > Thank you in advance
> > > > > Christophe Baume
> > > > > _______________________________________________
> > > > > Qgis-user mailing list
> > > > > Qgis-user at lists.osgeo.org
> > > > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > Yves Jacolin
> > > http://yjacolin.gloobe.org
> Yves Jacolin
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110413/527f9c4e/attachment.html>
