[Qgis-user] Delimited text plugin
Jerry Bond
gbond at rochester.rr.com
Wed Apr 13 08:08:51 PDT 2011
Hi List --
Using QGIS installed on Debian Squeeze (actually MEPIS 11) from deb repo
listed on website. Help says the version is 1.4 (correct?). Let me say
what excellent work you are all doing. I use QGIS for my relatively
simple needs and it is terrific.
My suggestion: when I tried to use the delimited text plugin I had
problems, so clicked on Help and read the message. But at least for me
it turned out that no quotes are allowed to delimit text fields. That
is mentioned in the example below the list of requirements, but it would
be much easier for the first-time user if the list read this way (also
edited for consistency):
*To view a delimited text file as layer, the text file must contain:
--A delimited header row of field names. This must be the first line in
the text file.
--An X and Y field. These fields can have any name.
--Text fields delimited without quotes (")
--X and Y coordinates specified as a number. The coordinate system is
not important.*
Minor, but I hope it may help.
Jerry Bond
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110413/aad42007/attachment.html>
