On Sat, Apr 16, 2011 at 8:32 PM, Saber <razmjooeis at faunalia.co.uk> wrote: > Hi all, > > Is there an option to rotate a symbol in the New Symbology > Ruled Based Yes :) In case you would like to rotate the symbol using a data-defined rotation while using the rule based renderer then the answer would be no. Martin
