[Qgis-user] Vector layers problem
Paul Lens paul.lens at base.be
Mon Apr 18 06:00:16 PDT 2011
Hello,
I had the same problem in 1.5 on windows Vista 32bits.
It's much better now (running 1.6).
If I remember well, the same problem occured in 1.6.
At a certain moment, I disabled/unloaded several plugins I didn't use.
Can't remember if it was linked with this problem or another one.
Regards,
Paul Lens
On 18/04/2011 11:38, Pedro VenĂ¢ncio wrote:
> Hello,
>   For some time I have detected a problem when I load raster and vector layers. When I turn off a vector layer, it does not disappear from the map, I have to turn on and off again at the TOC so that it effectively disappears.
>   This behavior happens to me both in 1.6 and 1.7 nightly builds, on Windows only (XP and 7), Linux does not show this behavior. I've tested on multiple machines.
>   Is this a known problem?
>   Thanks!
> Regards,
> Pedro VenĂ¢ncio
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20110418/03b8a877/attachment.html>
