[Qgis-user] styling a KML/KMZ file using QGIS?
maning sambale
emmanuel.sambale at gmail.com
Mon Apr 18 18:49:33 PDT 2011
You can use the qgis2google plugin, but I don't think it can extrude
polygons as shown in the link you provided.
http://gis-lab.info/qa/qgis2google-eng.html
You need to compile from source if you use linux or mac.
On Tue, Apr 19, 2011 at 6:16 AM, Ryan Dalton <ryankdalton at gmail.com> wrote:
> I was wondering if QGIS (or any plugins) allow you to "style" a layer
> (shapefile in my case), and then export the shapefile and style into a
> KML/KMZ that will allow the user to open the KML/KMZ in Google Earth and see
> the layer symbolized the same way that it looked in QGIS. Whenever I export
> to KML and load into Google Earth, I only get the online boundaries in a
> single color.
> Example, unique colors of US States where each state is a different color.
> It looks like the Shape2KML tool does this, but I'm wondering if this type
> of function has been implemented in QGIS. See examples here for a better
> visual:
> http://www.zonums.com/shp2kml.html
> Thanks.
> Qgis-user mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
