[Qgis-user] styling a KML/KMZ file using QGIS?
John C. Tull
jctull at gmail.com
Thu Apr 21 15:03:27 PDT 2011
Hi all,
Unfortunately, this plugin causes a segmentation fault for me, so it is still unusable. I've pasted a gdb log running a debug build. My test was to open the application, then try to load a simple test shapefile (although this crash appears to occur on loading any vector data source). I don't know if this will help determine what the cause is or not. Disabling the plugin results in normal behavior for QGIS.
Cheers,
John
gdb ~/Applications/QGIS.app/Contents/MacOS/QGIS
GNU gdb 6.3.50-20050815 (Apple version gdb-1515) (Sat Jan 15 08:33:48 UTC 2011)
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "x86_64-apple-darwin"...
warning: Unable to read symbols for QtSql.framework/Versions/4/QtSql (file not found).
warning: Unable to read symbols from "QtSql" (not yet mapped into memory).
warning: Unable to read symbols for QtXml.framework/Versions/4/QtXml (file not found).
warning: Unable to read symbols from "QtXml" (not yet mapped into memory).
warning: Unable to read symbols for QtCore.framework/Versions/4/QtCore (file not found).
warning: Unable to read symbols from "QtCore" (not yet mapped into memory).
warning: Unable to read symbols for QtGui.framework/Versions/4/QtGui (file not found).
warning: Unable to read symbols from "QtGui" (not yet mapped into memory).
warning: Unable to read symbols for QtNetwork.framework/Versions/4/QtNetwork (file not found).
warning: Unable to read symbols from "QtNetwork" (not yet mapped into memory).
warning: Unable to read symbols for QtSvg.framework/Versions/4/QtSvg (file not found).
warning: Unable to read symbols from "QtSvg" (not yet mapped into memory).
Reading symbols for shared libraries ....r.........u... done
n
(gdb) run
Starting program: /Users/jctull/Applications/QGIS.app/Contents/MacOS/QGIS
Reading symbols for shared libraries .+.+++++++.....+++++++.................................................................................................. done
Debug: /Users/jctull/sources/qgis/trunk/src/app/main.cpp: 337: (main) Files specified on command line: 1
Reading symbols for shared libraries . done
Reading symbols for shared libraries warning: Could not find object file "/Users/qdc/Projects/main/tools/hijack/ahs/build/ahs.build/Release FAT/ah_hermes.build/Objects-normal/x86_64/ah_private.o" - no debug information available for "ah_private.c".
warning: Could not find object file "/Users/qdc/Projects/main/tools/hijack/ahs/build/ahs.build/Release FAT/ah_hermes.build/Objects-normal/x86_64/ah_cl.o" - no debug information available for "ah_cl.c".
warning: Could not find object file "/Users/qdc/Projects/main/tools/hijack/ahs/build/ahs.build/Release FAT/ah_hermes.build/Objects-normal/x86_64/ah_serv.o" - no debug information available for "ah_serv.c".
warning: Could not find object file "/Users/qdc/Projects/main/tools/hijack/ahs/build/ahs.build/Release FAT/ah_hermes.build/Objects-normal/x86_64/main.o" - no debug information available for "main.c".
warning: Could not find object file "/Users/qdc/Projects/main/tools/hijack/ahs/build/ahs.build/Release FAT/ah_hermes.build/Objects-normal/x86_64/rbuffer.o" - no debug information available for "rbuffer.c".
warning: Could not find object file "/Users/qdc/Projects/main/tools/hijack/ahs/build/ahs.build/Release FAT/ah_hermes.build/Objects-normal/x86_64/megamix.o" - no debug information available for "megamix.c".
warning: Could not find object file "/Users/qdc/Projects/main/tools/hijack/ahs/build/ahs.build/Release FAT/ah_hermes.build/Objects-normal/x86_64/resampler.o" - no debug information available for "resampler.c".
warning: Could not find object file "/Users/qdc/Projects/main/tools/hijack/ahs/build/ahs.build/Release FAT/ah_hermes.build/Objects-normal/x86_64/coreaudio.o" - no debug information available for "coreaudio.c".
. done
Warning: loading of qgis translation failed [/Users/jctull/Applications/QGIS.app/Contents/MacOS/../Resources/i18n//qgis_en_US]
Warning: loading of qt translation failed [/Developer/Applications/Qt/translations/qt_en_US]
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 6900: (namUpdate) setCacheDirectory: /Users/jctull/.qgis/cache/
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 6901: (namUpdate) setMaximumCacheSize: 52428800
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 6904: (namUpdate) cacheDirectory: /Users/jctull/.qgis/cache/
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 6905: (namUpdate) maximumCacheSize: 52428800
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsdistancearea.cpp: 161: (setEllipsoid) setEllipsoid: a=6.37814e+06, b=6.37814e+06, 1/f=298.257
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 348: (createFromProj4) proj4: +proj=longlat +ellps=WGS84 +no_defs
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 377: (createFromProj4) proj string supplied has no +a argument
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 539: (getRecord) running query: select * from tbl_srs where parameters='+proj=longlat +ellps=WGS84 +no_defs'
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 561: (getRecord) trying system srs.db
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 616: (getRecord) retrieved: select * from tbl_srs where parameters='+proj=longlat +ellps=WGS84 +no_defs'
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 405: (createFromProj4) proj4string match search for srsid returned srsid: 3239
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsscalecalculator.cpp: 43: (setMapUnits) Map units set to 2
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsscalecalculator.cpp: 138: (calculateGeographicDistance) Distance across map extent (m): 0
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsscalecalculator.cpp: 89: (calculate) Using conversionFactor of 39.3701
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsscalecalculator.cpp: 92: (calculate) Can't calculate scale from the input values
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvasmap.cpp: 47: (resize) resizing to 1x1
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 194: (adjustExtentToSize) Map units per pixel (x,y) : 0, 0
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 195: (adjustExtentToSize) Pixmap dimensions (x,y) : 1, 1
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 196: (adjustExtentToSize) Extent dimensions (x,y) : 0, 0
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 197: (adjustExtentToSize) 0.0000000000000000,0.0000000000000000 : 0.0000000000000000,0.0000000000000000
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 208: (adjustExtentToSize) Scale (assuming meters as map units) = 1:0
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvasmap.cpp: 47: (resize) resizing to 100x30
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 195: (adjustExtentToSize) Pixmap dimensions (x,y) : 100, 30
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvas.cpp: 1309: (connectNotify) QgsMapCanvas connected to 2layersChanged()
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgsmeasuredialog.cpp: 273: (convertMeasurement) We're measuring on an ellipsoid or using projections, the system is returning meters
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgsmeasuredialog.cpp: 283: (convertMeasurement) Converting 1 meters
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgsmeasuredialog.cpp: 289: (convertMeasurement) to 3.28084 feet
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgsmeasuredialog.cpp: 283: (convertMeasurement) Converting 0 meters
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgsmeasuredialog.cpp: 289: (convertMeasurement) to 0 feet
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 835: (updateFullExtent) called.
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 892: (updateFullExtent) Full extent: 179769313486231570814527423731704356798070567525844996598917476803157260780028538760589558632766878171540458953514382464234321326889464182768467546703537516986049910576551282076245490090389328944075868508455133942304583236903222948165808559332123348274797826204144723168738177180919299881250404026184124858368.0000000000000000,179769313486231570814527423731704356798070567525844996598917476803157260780028538760589558632766878171540458953514382464234321326889464182768467546703537516986049910576551282076245490090389328944075868508455133942304583236903222948165808559332123348274797826204144723168738177180919299881250404026184124858368.0000000000000000 : -179769313486231570814527423731704356798070567525844996598917476803157260780028538760589558632766878171540458953514382464234321326889464182768467546703537516986049910576551282076245490090389328944075868508455133942304583236903222948165808559332123348274797826204144723168738177180919299881250404026184124858368.0000000000000000,-179769313486231570814527423731704356798070567525844996598917476803157260780028538760589558632766878171540458953514382464234321326889464182768467546703537516986049910576551282076245490090389328944075868508455133942304583236903222948165808559332123348274797826204144723168738177180919299881250404026184124858368.0000000000000000
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 223: (render) ========== Rendering ==========
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 227: (render) empty extent... not rendering
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 798: (setMapUnits) Projection has linear units of Meter
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 669: (setDestinationCrs) * Setting destCRS : = +proj=utm +zone=11 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 670: (setDestinationCrs) * DestCRS.srsid() = 2288
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 673: (setDestinationCrs) Setting DistArea CRS to 2288
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsscalecalculator.cpp: 43: (setMapUnits) Map units set to 0
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 655: (setProjectionsEnabled) Adjusting DistArea projection on/off
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmaptool.cpp: 82: (activate) Cursor has been set
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 83: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis for provider plugins
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libcoordinatecaptureplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libcopyrightlabelplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libdelimitedtextplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libdelimitedtextprovider.so : ... loaded ok (null file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libdiagramoverlay.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libdisplacementplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libdxf2shpconverterplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libevis.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgdalprovider.so : ... loaded ok (null file filters)
Reading symbols for shared libraries .. done
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgeorefplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgpsimporterplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgpxprovider.so : ... loaded ok (null file filters)
Reading symbols for shared libraries ............ done
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassprovider.so : ... loaded ok (null file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassrasterprovider.so : ... loaded ok (null file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libinterpolationplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libmemoryprovider.so : ... loaded ok (null file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libnortharrowplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libofflineeditingplugin.so : ..invalid (no type)
Reading symbols for shared libraries ... done
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1320: (createFilters) Driver count: 47
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: REC
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: Memory
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: NAS
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: LIBKML
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: MSSQLSpatial
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: PCIDSK
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: GPSTrackMaker
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: VFK
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: PGDump
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: GPSBabel
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: SUA
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: OpenAir
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: PDS
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: WFS
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: HTF
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1493: (createFilters) fileVectorFilters, unknown driver: AeronavFAA
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libogrprovider.so : ... loaded ok (and with 22 file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/liboracleplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libosmprovider.so : ... loaded ok (null file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libpostgresprovider.so : ... loaded ok (null file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libqgis2googleplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/librasterterrainplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libroadgraphplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libscalebarplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libspatialiteprovider.so : ... loaded ok (null file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libspatialqueryplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libspitplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libsqlanywhereplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/providers/sqlanywhere/qgssqlanywhereprovider.cpp: 2297: (providerKey) Returning provider key sqlanywhere
Debug: /Users/jctull/sources/qgis/trunk/src/providers/sqlanywhere/qgssqlanywhereprovider.cpp: 2306: (description) Returning provider description SQL Anywhere data provider
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libsqlanywhereprovider.so : ... loaded ok (null file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libwfsplugin.so : ..invalid (no type)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libwfsprovider.so : ... loaded ok (null file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 216: (QgsProviderRegistry) Checking /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libwmsprovider.so : ... loaded ok (null file filters)
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 4693: (loadPythonSupport) load library /Users/jctull/Applications/QGIS.app/Contents/MacOS/lib/qgispython (1.7.0)
Python support ENABLED :-)
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libdelimitedtextprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 314: (loadCppPlugin) plugin object name:
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 320: (loadCppPlugin) object name to diagramoverlay
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 322: (loadCppPlugin) plugin object name now: qgis_plugin_diagramoverlay
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 327: (loadCppPlugin) setting plugin parent
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgdalprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 320: (loadCppPlugin) object name to georefplugin
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 322: (loadCppPlugin) plugin object name now: qgis_plugin_georefplugin
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgpxprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/providers/grass/qgsgrass.cpp: 129: (init) GRASS gisBase from GISBASE env var is:
Debug: /Users/jctull/sources/qgis/trunk/src/providers/grass/qgsgrass.cpp: 290: (isValidGrassBaseDir) isValidGrassBaseDir()
Debug: /Users/jctull/sources/qgis/trunk/src/providers/grass/qgsgrass.cpp: 134: (init) GRASS gisBase from QSettings is:
Debug: /Users/jctull/sources/qgis/trunk/src/providers/grass/qgsgrass.cpp: 149: (init) GRASS gisBase from configure is: /Applications/GRASS-6.4.app/Contents/MacOS
Debug: /Users/jctull/sources/qgis/trunk/src/providers/grass/qgsgrass.cpp: 200: (init) Valid GRASS gisBase is: /Applications/GRASS-6.4.app/Contents/MacOS
Debug: /Users/jctull/sources/qgis/trunk/src/providers/grass/qgsgrass.cpp: 231: (init) set PATH: /Applications/GRASS-6.4.app/Contents/MacOS/bin:/Applications/GRASS-6.4.app/Contents/MacOS/scripts:/Users/jctull/Applications/QGIS.app/Contents/MacOS/../Resources/grass/scripts/:~/.local/bin:~/bin:/usr/local/qt-4.7/bin:/usr/local/Trolltech/Qt-4.6.0/bin:/System/Library/Frameworks/Python.framework/Versions/2.6/bin:/usr/local/bin:/Developer/Applications/Qt-4.6.0/bin:/Developer/usr/llvm-gcc-4.2/bin:/Library/Frameworks/Ghostscript.framework/bin:/Library/Frameworks/MapServer.framework/Programs:/Library/Frameworks/SQLite3.framework/unix/bin:/usr/local/pgsql/bin:/Library/Frameworks/GDAL.framework/unix/bin:/Library/Frameworks/GEOS.framework/unix/bin:/Library/Frameworks/UnixImageIO.framework/unix/bin:/Library/Frameworks/GSL.framework/unix/bin:/Library/Frameworks/PROJ.framework/unix/bin:/Library/Frameworks/PDFlib.framework/unix/bin:/Library/Frameworks/GD.framework/unix/bin:/Library/Frameworks/GraphicsMagick.framework/unix/bin:/System/Library/Frameworks/Python.framework/Versions/Current/bin:/usr/local/pgsql/bin/:/usr/local/sbin:/usr/X11/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/git/bin:/sbin:/bin:/usr/sbin:/usr/bin
Debug: /Users/jctull/sources/qgis/trunk/src/providers/grass/qgsgrass.cpp: 238: (init) set PYTHONPATH: /Applications/GRASS-6.4.app/Contents/MacOS/etc/python:
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvas.cpp: 1309: (connectNotify) QgsMapCanvas connected to 2renderComplete(QPainter*)
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 320: (loadCppPlugin) object name to grassplugin
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 322: (loadCppPlugin) plugin object name now: qgis_plugin_grassplugin
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassrasterprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libmemoryprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libogrprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libosmprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libpostgresprovider.so
Debug: Unable to load translator
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 320: (loadCppPlugin) object name to qgis2googleplugin
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 322: (loadCppPlugin) plugin object name now: qgis_plugin_qgis2googleplugin
Warning: QLayout: Attempting to add QLayout "" to RgShortestPathWidget "ShortestPathDock", which already has a layout
Warning: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvas.cpp: 1309: (connectNotify) QgsMapCanvas connected to 2extentsChanged()
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 320: (loadCppPlugin) object name to roadgraphplugin
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 322: (loadCppPlugin) plugin object name now: qgis_plugin_roadgraphplugin
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libspatialiteprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libsqlanywhereprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libwfsprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 453: (checkCppPlugin) Failed to get name, description, or type for /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libwmsprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 403: (restoreSessionPlugins) Loading python plugins
Loaded : Create custom db queries (package: customdbquery)
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvas.cpp: 1309: (connectNotify) QgsMapCanvas connected to 2destroyed(QObject*)
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvas.cpp: 1309: (connectNotify) QgsMapCanvas connected to 2mapToolSet(QgsMapTool*)
Loaded : Freehand editing (package: freehandEditing)
Reading symbols for shared libraries .... done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/core/src/multiarray/multiarraymodule_onefile.o" - no debug information available for "numpy/core/src/multiarray/multiarraymodule_onefile.c".
warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/libnpymath.a(npy_math.o)" - no debug information available for "build/src.macosx-10.6-universal-2.6/numpy/core/src/npymath/npy_math.c".
warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/libnpymath.a(ieee754.o)" - no debug information available for "build/src.macosx-10.6-universal-2.6/numpy/core/src/npymath/ieee754.c".
warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/libnpymath.a(halffloat.o)" - no debug information available for "numpy/core/src/npymath/halffloat.c".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/core/src/umath/umathmodule_onefile.o" - no debug information available for "numpy/core/src/umath/umathmodule_onefile.c".
warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/libnpymath.a(npy_math_complex.o)" - no debug information available for "build/src.macosx-10.6-universal-2.6/numpy/core/src/npymath/npy_math_complex.c".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/build/src.macosx-10.6-universal-2.6/numpy/core/src/_sortmodule.o" - no debug information available for "build/src.macosx-10.6-universal-2.6/numpy/core/src/_sortmodule.c".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/core/blasdot/_dotblas.o" - no debug information available for "numpy/core/blasdot/_dotblas.c".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/build/src.macosx-10.6-universal-2.6/numpy/core/src/scalarmathmodule.o" - no debug information available for "build/src.macosx-10.6-universal-2.6/numpy/core/src/scalarmathmodule.c".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/lib/src/_compiled_base.o" - no debug information available for "numpy/lib/src/_compiled_base.c".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/linalg/lapack_litemodule.o" - no debug information available for "numpy/linalg/lapack_litemodule.c".
warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/linalg/python_xerbla.o" - no debug information available for "numpy/linalg/python_xerbla.c".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/fft/fftpack_litemodule.o" - no debug information available for "numpy/fft/fftpack_litemodule.c".
warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/fft/fftpack.o" - no debug information available for "numpy/fft/fftpack.c".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/random/mtrand/mtrand.o" - no debug information available for "numpy/random/mtrand/mtrand.c".
warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/random/mtrand/randomkit.o" - no debug information available for "numpy/random/mtrand/randomkit.c".
warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/random/mtrand/initarray.o" - no debug information available for "numpy/random/mtrand/initarray.c".
warning: Could not find object file "/Users/fonnescj/Code/numpy/build/temp.macosx-10.6-universal-2.6/numpy/random/mtrand/distributions.o" - no debug information available for "numpy/random/mtrand/distributions.c".
. done
Loaded : manageR (package: manageR)
Loaded : Map Themes Builder (package: mapThemes)
/Users/jctull/.qgis/python/plugins/openlayers/openlayers_plugin.py:218: DeprecationWarning: QgsCoordinateReferenceSystem.createFromEpsg() is deprecated
if not self.__coordRSGoogle.createFromEpsg(idEpsgRSGoogle):
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvas.cpp: 1309: (connectNotify) QgsMapCanvas connected to 2scaleChanged(double)
Loaded : OpenLayers Plugin (package: openlayers)
Loaded : QGIS File Browser (package: QGISFileBrowser)
Loaded : RT Sql Layer (package: rt_sql_layer)
/Library/Frameworks/GDAL.framework/Versions/1.8/Python/site-packages/osgeo/gdal.py:80: DeprecationWarning: gdal.py was placed in a namespace, it is now available as osgeo.gdal
DeprecationWarning)
Loaded : DEM relief shader (package: shadedrelief)
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/agg24/src/agg_curves.o" - no debug information available for "agg24/src/agg_curves.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/agg24/src/agg_bezier_arc.o" - no debug information available for "agg24/src/agg_bezier_arc.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/agg24/src/agg_trans_affine.o" - no debug information available for "agg24/src/agg_trans_affine.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/agg24/src/agg_vcgen_stroke.o" - no debug information available for "agg24/src/agg_vcgen_stroke.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/CXX/cxx_extensions.o" - no debug information available for "CXX/cxx_extensions.cxx".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/CXX/cxxsupport.o" - no debug information available for "CXX/cxxsupport.cxx".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/CXX/IndirectPythonInterface.o" - no debug information available for "CXX/IndirectPythonInterface.cxx".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/CXX/cxxextensions.o" - no debug information available for "CXX/cxxextensions.c".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/src/agg_py_transforms.o" - no debug information available for "src/agg_py_transforms.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/src/path_cleanup.o" - no debug information available for "src/path_cleanup.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/src/path.o" - no debug information available for "src/path.cpp".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/src/ft2font.o" - no debug information available for "src/ft2font.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/src/mplutils.o" - no debug information available for "src/mplutils.cpp".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/src/nxutils.o" - no debug information available for "src/nxutils.c".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/src/_png.o" - no debug information available for "src/_png.cpp".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/src/cntr.o" - no debug information available for "src/cntr.c".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/src/image.o" - no debug information available for "src/image.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/agg24/src/agg_image_filters.o" - no debug information available for "agg24/src/agg_image_filters.cpp".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/lib/matplotlib/delaunay/_delaunay.o" - no debug information available for "lib/matplotlib/delaunay/_delaunay.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/lib/matplotlib/delaunay/VoronoiDiagramGenerator.o" - no debug information available for "lib/matplotlib/delaunay/VoronoiDiagramGenerator.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/lib/matplotlib/delaunay/delaunay_utils.o" - no debug information available for "lib/matplotlib/delaunay/delaunay_utils.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/lib/matplotlib/delaunay/natneighbors.o" - no debug information available for "lib/matplotlib/delaunay/natneighbors.cpp".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/lib/matplotlib/tri/_tri.o" - no debug information available for "lib/matplotlib/tri/_tri.cpp".
. done
Reading symbols for shared libraries warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/agg24/src/agg_trans_affine.o" - no debug information available for "agg24/src/agg_trans_affine.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/agg24/src/agg_vcgen_dash.o" - no debug information available for "agg24/src/agg_vcgen_dash.cpp".
warning: Could not find object file "/Users/fonnescj/Code/matplotlib/build/temp.macosx-10.6-universal-2.6/src/backend_agg.o" - no debug information available for "src/backend_agg.cpp".
. done
Loaded : Statist (package: statist)
Loaded : Table Manager (package: tablemanager)
Loaded : WPS-Client (package: wps)
/Users/jctull/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py:283: DeprecationWarning: the sets module is deprecated
mod = _builtin_import(name, globals, locals, fromlist, level)
Loaded : fTools (package: fTools)
Loaded : Plugin Installer (package: plugin_installer)
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgspluginregistry.cpp: 431: (restoreSessionPlugins) Plugin loading completed
Debug: /Users/jctull/sources/qgis/trunk/src/core/raster/qgsrasterlayer.cpp: 185: (buildSupportedRasterFileFilter) Entered
Debug: /Users/jctull/sources/qgis/trunk/src/core/raster/qgsrasterlayer.cpp: 2164: (loadProviderLibrary) theProviderKey = gdal
Debug: /Users/jctull/sources/qgis/trunk/src/core/raster/qgsrasterlayer.cpp: 2168: (loadProviderLibrary) myLibPath = /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgdalprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/core/raster/qgsrasterlayer.cpp: 2190: (loadProviderLibrary) Library name is /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgdalprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/core/raster/qgsrasterlayer.cpp: 2198: (loadProviderLibrary) Loaded data provider library
Debug: /Users/jctull/sources/qgis/trunk/src/providers/gdal/qgsgdalprovider.cpp: 1640: (buildSupportedRasterFileFilter) Entered
Debug: /Users/jctull/sources/qgis/trunk/src/providers/gdal/qgsgdalprovider.cpp: 1805: (buildSupportedRasterFileFilter) Raster filter list built: [GDAL] All files (*);;[GDAL] ERDAS Compressed Wavelets (*.ecw *.ECW);;[GDAL] ERDAS JPEG2000 (*.jp2 *.j2k *.JP2 *.J2K);;[GDAL] MrSID Generation 4 / Lidar (*.view *.VIEW);;[GDAL] Multi-resolution Seamless Image Database (*.sid *.SID);;[GDAL] Geospatial PDF (*.pdf *.PDF);;[GDAL] Virtual Raster (*.vrt *.VRT);;[GDAL] GeoTIFF (*.tif *.tiff *.TIF *.TIFF);;[GDAL] National Imagery Transmission Format (*.ntf *.NTF);;[GDAL] Raster Product Format TOC format (*.toc *.TOC);;[GDAL] Erdas Imagine Images (*.img *.IMG);;[GDAL] Ground-based SAR Applications Testbed File Format (*.gff *.GFF);;[GDAL] Arc/Info ASCII Grid (*.asc *.ASC);;[GDAL] SDTS Raster (*.ddf *.DDF);;[GDAL] DTED Elevation Raster (*.dt0 *.dt1 *.dt2 *.DT0 *.DT1 *.DT2);;[GDAL] Portable Network Graphics (*.png *.PNG);;[GDAL] JPEG JFIF (*.jpg *.jpeg *.JPG *.JPEG);;[GDAL] Japanese DEM (*.mem *.MEM);;[GDAL] Graphics Interchange Format (*.gif *.GIF);;[GDAL] Graphics Interchange Format (*.gif *.GIF);;[GDAL] Envisat Image Format (*.n1 *.N1);;[GDAL] X11 PixMap Format (*.xpm *.XPM);;[GDAL] MS Windows Device Independent Bitmap (*.bmp *.BMP);;[GDAL] PCIDSK Database File (*.pix *.PIX);;[GDAL] PCRaster Raster File (*.map *.MAP);;[GDAL] ILWIS Raster Map (*.mpr *.mpl *.MPR *.MPL);;[GDAL] SGI Image File Format 1.0 (*.rgb *.RGB);;[GDAL] SRTMHGT File Format (*.hgt *.HGT);;[GDAL] Leveller heightfield (*.ter *.TER);;[GDAL] Terragen heightfield (*.ter *.TER);;[GDAL] GMT NetCDF Grid Format (*.nc *.NC);;[GDAL] Network Common Data Format (*.nc *.NC);;[GDAL] GRIdded Binary (*.grb *.GRB);;[GDAL] Raster Matrix Format (*.rsw *.RSW);;[GDAL] EUMETSAT Archive native (*.nat *.NAT);;[GDAL] Idrisi Raster A.1 (*.rst *.RST);;[GDAL] Golden Software ASCII Grid (*.grd *.GRD);;[GDAL] Golden Software Binary Grid (*.grd *.GRD);;[GDAL] Golden Software 7 Binary Grid (*.grd *.GRD);;[GDAL] DRDC COASP SAR Processor Raster (*.hdr *.HDR);;[GDAL] R Object Data Store (*.rda *.RDA);;[GDAL] Portable Pixmap Format (*.pnm *.PNM);;[GDAL] Vexcel MFF Raster (*.hdr *.HDR);;[GDAL] VTP .bt (Binary Terrain) 1.3 Format (*.bt *.BT);;[GDAL] FARSITE v.4 Landscape File (*.lcp *.LCP);;[GDAL] NOAA Vertical Datum .GTX (*.gtx *.GTX);;[GDAL] NTv2 Datum Grid Shift (*.gsb *.GSB);;[GDAL] Swedish Grid RIK (*.rik *.RIK);;[GDAL] USGS Optional ASCII DEM (*.dem *.DEM);;[GDAL] GeoSoft Grid Exchange Format (*.gxf *.GXF);;[GDAL] Hierarchical Data Format Release 5 (*.hdf5 *.HDF5);;[GDAL] Northwood Numeric Grid Format .grd/.tab (*.grd *.GRD);;[GDAL] Northwood Classified Grid Format .grc/.tab (*.grc *.GRC);;[GDAL] ARC Digitized Raster Graphics (*.gen *.GEN);;[GDAL] Standard Raster Product (*.img *.IMG);;[GDAL] Magellan topo (*.blx *.BLX);;[GDAL] Rasterlite (*.sqlite *.SQLITE);;[GDAL] SAGA GIS Binary Grid (*.sdat *.SDAT);;[GDAL] ASCII Gridded XYZ (*.xyz *.XYZ);;[GDAL] HF2/HFZ heightfield raster (*.hf2 *.HF2)
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvas.cpp: 1309: (connectNotify) QgsMapCanvas connected to 2xyCoordinates(QgsPoint)
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvas.cpp: 1309: (connectNotify) QgsMapCanvas connected to 2selectionChanged(QgsMapLayer*)
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvas.cpp: 1309: (connectNotify) QgsMapCanvas connected to 2zoomLastStatusChanged(bool)
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvas.cpp: 1309: (connectNotify) QgsMapCanvas connected to 2zoomNextStatusChanged(bool)
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapcanvasmap.cpp: 47: (resize) resizing to 955x898
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 195: (adjustExtentToSize) Pixmap dimensions (x,y) : 955, 898
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 565: (QgisApp) Tips are disabled
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 572: (QgisApp)
Application Settings:
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 573: (QgisApp) Application state:
Prefix : /Users/jctull/Applications/QGIS.app/Contents/MacOS
Plugin Path : /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis
Package Data Path : /Users/jctull/Applications/QGIS.app/Contents/MacOS/../Resources
Active Theme Name : gis
Active Theme Path : :/images/themes/gis/
Default Theme Path : :/images/themes/default/
SVG Search Paths : /Users/jctull/Documents/Map_Data/Symbols/Custom_svg
/Users/jctull/Applications/QGIS.app/Contents/MacOS/../Resources/svg/
/Users/jctull/.qgis/svg/
User DB Path : /Users/jctull/Applications/QGIS.app/Contents/MacOS/../Resources/resources/qgis.db
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 574: (QgisApp)
Debug: /Users/jctull/sources/qgis/trunk/src/app/main.cpp: 638: (main) Number of files in myFileList: 0
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 194: (adjustExtentToSize) Map units per pixel (x,y) : 0.00209424, 0.00222717
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 196: (adjustExtentToSize) Extent dimensions (x,y) : 2, 2
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 197: (adjustExtentToSize) -1.0000000000000000,-1.0000000000000000 : 1.0000000000000000,1.0000000000000000
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 208: (adjustExtentToSize) Scale (assuming meters as map units) = 1:6.31324
Debug: /Users/jctull/sources/qgis/trunk/src/gui/qgsmapoverviewcanvas.cpp: 174: (drawExtentRect) panning: extent to widget: [-2147483648,-2147483648] [1x1]
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 261: (render) Starting to render layer stack.
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 543: (render) Done rendering map layers
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgspallabeling.cpp: 991: (drawLabeling) LABELING work: 0 ms ... labels# 0
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgspallabeling.cpp: 1112: (drawLabeling) LABELING draw: 0 ms
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaprenderer.cpp: 621: (render) Rendering completed in (seconds): 0.001
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 3059: (openFile) Adding /Users/jctull/Desktop/temp/temp.shp to the map canvas
Debug: /Users/jctull/sources/qgis/trunk/src/app/qgisapp.cpp: 2126: (addVectorLayers) completeBaseName: temp
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaplayer.cpp: 54: (QgsMapLayer) lyrname is 'temp'
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaplayer.cpp: 60: (QgsMapLayer) layerName is 'temp'
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 362: (getProvider) Library name is /Users/jctull/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libogrprovider.so
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 368: (getProvider) Loaded data provider library
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 369: (getProvider) Attempting to resolve the classFactory function
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 376: (getProvider) Getting pointer to a dataProvider object from the library
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 102: (QgsOgrProvider) Data source uri is /Users/jctull/Desktop/temp/temp.shp
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 153: (QgsOgrProvider) mFilePath: /Users/jctull/Desktop/temp/temp.shp
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 154: (QgsOgrProvider) mLayerIndex: 0
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 155: (QgsOgrProvider) mLayerName:
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 156: (QgsOgrProvider) mSubsetString:
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 172: (QgsOgrProvider) Data source is valid
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 173: (QgsOgrProvider) OGR Driver was ESRI Shapefile
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 295: (setSubsetString) checking validity
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 297: (setSubsetString) Done checking validity
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 387: (getProvider) Instantiated the data provider plugin
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsproviderregistry.cpp: 388: (getProvider) provider name: ogr
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsvectorlayer.cpp: 2718: (setDataProvider) Instantiated the data provider plugin
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 664: (extent) Starting get extent
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 702: (extent) Finished get extent
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsvectorlayer.cpp: 2732: (setDataProvider) Extent of layer: 2221780.9604755183681846,13238574.4353034887462854 : 3963658.1884304755367339,15793929.8881961740553379
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsvectorlayer.cpp: 4341: (setCoordinateSystem) ----- Computing Coordinate System
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1850: (crs) entering.
Debug: /Users/jctull/sources/qgis/trunk/src/providers/ogr/qgsogrprovider.cpp: 1829: (crsFromWkt) +proj=tmerc +lat_0=34.75 +lon_0=-118.5833333333333 +k=0.9999 +x_0=800000.0000101599 +y_0=3999999.99998984 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=us-ft +no_defs
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 288: (createFromWkt) wkt: PROJCS["unnamed",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AUTHORITY["EPSG","4269"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",34.75],PARAMETER["central_meridian",-118.5833333333333],PARAMETER["scale_factor",0.9999],PARAMETER["false_easting",2624666.6667],PARAMETER["false_northing",13123333.3333],UNIT["Foot_US",0.3048006096012192]]
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 348: (createFromProj4) proj4: +proj=tmerc +lat_0=34.75 +lon_0=-118.5833333333333 +k=0.9999 +x_0=800000.0000101599 +y_0=3999999.99998984 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=us-ft +no_defs
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 539: (getRecord) running query: select * from tbl_srs where parameters='+proj=tmerc +lat_0=34.75 +lon_0=-118.5833333333333 +k=0.9999 +x_0=800000.0000101599 +y_0=3999999.99998984 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=us-ft +no_defs'
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 616: (getRecord) retrieved: select * from tbl_srs where parameters='+proj=tmerc +lat_0=34.75 +lon_0=-118.5833333333333 +k=0.9999 +x_0=800000.0000101599 +y_0=3999999.99998984 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=us-ft +no_defs'
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 405: (createFromProj4) proj4string match search for srsid returned srsid: 1381
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgscoordinatereferencesystem.cpp: 798: (setMapUnits) Projection has linear units of Foot
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsvectorlayer.cpp: 2949: (readSymbology) calling readXML
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgslabel.cpp: 747: (readXML) called for layer label properties, got node labelattributes
Debug: /Users/jctull/sources/qgis/trunk/src/core/qgsmaplayer.cpp: 105: (setLayerName) new name is 'temp'
Debug: /Users/jctull/sources/qgis/trunk/src/app/legend/qgslegendlayer.cpp: 92: (QgsLegendLayer) Connecting signals for updating icons, layer temp
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_INVALID_ADDRESS at address: 0x0000000000000000
0x000000011d2cb88b in qgis2google::setDefaultSettings (this=0x10583c990, layer=0x121265170) at /Users/jctull/sources/qgis/trunk/src/plugins/qgis2google2/qgis2google.cpp:181
181 QList<QgsSymbol *> symbols = vlayer->renderer()->symbols();
(gdb) tb
Breakpoint 1 at 0x11d2cb88b: file /Users/jctull/sources/qgis/trunk/src/plugins/qgis2google2/qgis2google.cpp, line 181.
(gdb)
