[Qgis-user] styling a KML/KMZ file using QGIS?
John C. Tull
jctull at gmail.com
Thu Apr 21 16:24:28 PDT 2011
Hi Jürgen,
Thanks for sorting that out for me. You are correct about the symbology-ng. This temp shapefile had a qml with symbology-ng, so I deleted that and tested again. It worked when reverting to the old symbology.
Cheers,
John
On Apr 21, 2011, at 3:24 PM, Jürgen E. Fischer wrote:
> Hi John,
> On Thu, 21. Apr 2011 at 15:03:27 -0700, John C. Tull wrote:
>> Unfortunately, this plugin causes a segmentation fault for me, so it is still unusable. I've pasted a gdb log running a debug build. My test was to open the application, then try to load a simple test shapefile (although this crash appears to occur on loading any vector data source). I don't know if this will help determine what the cause is or not. Disabling the plugin results in normal behavior for QGIS.
>> Debug: /Users/jctull/sources/qgis/trunk/src/app/legend/qgslegendlayer.cpp: 92: (QgsLegendLayer) Connecting signals for updating icons, layer temp
>> Program received signal EXC_BAD_ACCESS, Could not access memory.
>> Reason: KERN_INVALID_ADDRESS at address: 0x0000000000000000
>> 0x000000011d2cb88b in qgis2google::setDefaultSettings (this=0x10583c990, layer=0x121265170) at /Users/jctull/sources/qgis/trunk/src/plugins/qgis2google2/qgis2google.cpp:181
>> 181 QList<QgsSymbol *> symbols = vlayer->renderer()->symbols();
> Looks like qgis2google2 doesn't know about symbology-ng and assumes that you're
> not using it, but you probably aren't.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
