[Qgis-user] plugin Statistic dont work
    Goyo
    goyodiaz at gmail.com
    Fri Apr 22 14:57:23 PDT 2011
Hola Bettina,
the bug is now closed as fixed (thanks, Jürgen) so updating osgeo4w
should be enough.
If you used the standalone installer I don't know if you can update.
If you don't then do this:
1. Open C:\OSGeo4W\apps\Python25\lib\site-packages\matplotlib\backends\backend_agg.py
in notepad or any text editor. The exact path can vary if you
installed in a custom directory.
2. Look for this code (it should be lines 319, 320 and 321):
try: self._lastKey, self.renderer
except AttributeError: need_new_renderer = True
else:  need_new_renderer = (self._lastKey != key)
3. Change the second line (320) to this:
except (AttributeError, TypeError): need_new_renderer = True
4. Save changes and try again.
You can make a backup of the file before making any changes, just for
safety. But now that the bug is fixed updating osgeo4w is the right
way to go.
Goyo
2011/4/22 Betina Zucchino <bzucchino at yahoo.com.ar>
> Hola Goyo:
> Hablas en español?
> Te agradezco lo que me respondiste. Pero no manejo Python y no se que es lo que tendría que hacer con eso que figura en la página... Te pido disculpas, soy usuaria de qgis, pero sin idea de programación.
> Lo que alcancé a hacer es abrir una ventana de python 2.7 y pegar todas las sentencias que figuran en la pagina sin saber cómo continuar. Hice Debug...
> En fin,  muchas gracias igualmente.
> Betina
> --- El vie 22-abr-11, Goyo <goyodiaz at gmail.com> escribió:
> De: Goyo <goyodiaz at gmail.com>
> Asunto: Re: [Qgis-user] plugin Statistic dont work
> Para: "Betina Zucchino" <bzucchino at yahoo.com.ar>
> Cc: qgis-user at lists.osgeo.org
> Fecha: viernes, 22 de abril de 2011, 17:00
> > Traceback (most recent call last):
> >   File "C:\OSGeo4W\apps\Python25\lib\site-packages\matplotlib\backends\backend_qt4.py", line 168, in resizeEvent
> >     self.draw()
> >   File "C:\OSGeo4W\apps\Python25\lib\site-packages\matplotlib\backends\backend_qt4agg.py", line 130, in draw
> >     FigureCanvasAgg.draw(self)
> >   File "C:\OSGeo4W\apps\Python25\lib\site-packages\matplotlib\backends\backend_agg.py", line 313, in draw
> >     self.renderer = self.get_renderer()
> >   File "C:\OSGeo4W\apps\Python25\lib\site-packages\matplotlib\backends\backend_agg.py", line 319, in get_renderer
> > TypeError: 'sip.methoddescriptor' object is not callable
> There is an incompatibility between python and sip versions in osgeo4w
> affecting the qt4agg backend in matplotlib. I filed a bug about this
> some time ago[1]. I had to patch matplotlib in order to get the qt4agg
> backend working in osgeo4w, see the bug report for details.
> Goyo
> [1] http://trac.osgeo.org/osgeo4w/ticket/213
