[Qgis-user] v.to.db problem
Giovanni Manghi
giovanni.manghi at gmail.com
Sat Apr 23 11:53:36 PDT 2011
> Hi! all,
> I had to create two columns in attribute table for x,y coordinates. But,
> v.to.db in qgis has a problem in identifying more than one column from the
> drop down box. Because that dd box allows you to select only one box at a
> time neither you can type it in after that. So, either I go to grass for
> typing is possible in grass.
> Any solutions to this. It is irritating
known problem
http://trac.osgeo.org/qgis/ticket/1867
if you need it, supporting the bug fixing is highly recommended.
cheers
-- Giovanni --
